Old 07-19-2017, 08:08 PM
Melodic Wave Melodic Wave is offline
Default PT 10 using resources while in idle?
Hello, my win 7 PC seems to be getting more and more sluggish the past few months for no apparent reason. Now PT is taking longer and longer to boot. I see that while in idle PT is using 12% to 20% of the PC resources, which I don't understand why it's working so hard while standing still. My NI libraries are on an external HD, so that's not the issue. I have 16 gigs of RAM, 3.2 gigahertz quad core intel i5....I've only used around 250 gigs of a 1TB HD.... I've ran diagnostics and nothing is showing up as unusual..... I'm stumped because I don't know if PT is the cause or something awry in my PC somewhere, but the PC runs ok outside of running PT..... I'm almost to the point of upgrading to an SSD, but what's the use unless I buy PT12 to take advantage of all that RAM. At any rate, is it normal for PT to be revving that high in idle?
Old 07-20-2017, 07:45 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: PT 10 using resources while in idle?
Do you use a second hard drive for your sessions or are you only using the system drive? How full is it?
PT does tend to take over a computer's resources. Many will tell you an i5 is not enough CPU for PT.
YMMV
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Pro Tools Idle, CPU at 80% drenn Pro Tools HDX & HD Native Systems (Mac) 0 08-13-2014 02:56 PM
Crash when idle Stig Eliassen Pro Tools TDM Systems (Mac) 5 04-04-2012 09:32 AM
i7 idle temps. rhythmtechnologies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-12-2009 04:15 PM
pt8 - 90% cpu idle, 5% while playing? huh!? noahandrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-14-2009 07:56 AM
Mbox uses 50% cpu while idle bellisimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-09-2003 01:25 PM
