Old 01-27-2017, 02:57 AM
bucha bucha is offline
Default BIG PAN Bug in PT12.5.2
A small pic is better than a big speech (also available in PT 12.7.0, tested in Native and HDx) :
Old 01-27-2017, 03:38 AM
Carl Lie Carl Lie is offline
Default Re: BIG PAN Bug in PT12.5.2
can't tell from the small pic. Maybe I'm getting old.
Is the pan line drawn above offset toward center from right yet your seeing a complete move to the right side?
C
PT 2018.7 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 01-27-2017, 04:14 AM
JFreak's Avatar
JFreak JFreak is offline
Does it work differently in earlier versions? All I can see is panning from left to right in LCR realm, in which case the middle of the transition would be full center.
Janne
Old 01-27-2017, 07:13 AM
garret garret is offline
That looks fine to me. What's the problem? There won't be an overlap between left and right.
IMDB
Old 01-27-2017, 07:30 AM
simonchase simonchase is offline
It doesn't seem to match up perfectly. The result appears to be centre only for a while before the automation of the pan actually gets there. But it's hard to see from the waveform. It looks a little off to my eye though
PT Ultimate 2019.5 - Mbox 3 Pro ---- MacOS 10.12.6 - Mac Pro (Mid 2010) - 2 x 3.46 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 RAM - SSD Startup Disk ---- AJA Kona LHi PCIe
Old 01-27-2017, 07:50 AM
I just did it in 12.4 and it looks pretty much the same
IMDB
Old 01-31-2017, 02:55 AM
Sorry guys,
So the selection ends where the pan is at 0.
It begins at 19 on the left.
So, on the recording track, we should have sound on the left channel until the 0 position (and the decay should be linear ??).
It's pretty much the same thing on the right channel.
This "bug" remains for all the multi channel tracks from LCR to 7.1.
Thanks.
Old 01-31-2017, 04:27 AM
Hmm. Yes I just tried this in PT 10 and it is working correctly. My Selection is the same as yours. Beginning at 19 and ending at 0.
http://www.hostingpics.net/viewer.ph...31at122421.png
IMDB
Old 01-31-2017, 05:46 AM
joachim's Avatar
joachim joachim is offline
From an older thread : http://duc.avid.com/showthread.php?t=282160
that includes this link : http://www.pharoahaudio.com/pannerautotest.html ,
it seems, that the more breakpoints are around the 0 degree area, the better.
But it is tedious to put those additional breakpoints in (via insertion near center and write-to-all-enabled and only Pan enabled in the Automation Window).
My test in PT 11.3.1 (maybe valid for PT 12 as well):
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 01-31-2017, 06:21 AM
joachim's Avatar
Out of interest : if there is no signal generator as insert on the track, but a consolidated audio clip of the noise, is it still correct ?
Opening oversized PT12 HD session in non-HD PT12? mjpatey Pro Tools 12 6 01-10-2017 09:25 AM
PT12.5 GUI Lag TrentWilliams Pro Tools 12 0 04-15-2016 02:03 PM
Is there an upgrade from PT12 to PT12 HD? Hot Banana Studio Licensing & Accounts 16 11-21-2015 12:13 PM
PT12 and PT12 HD surround? theom Pro Tools 12 17 10-12-2015 09:27 AM
No PT12 available giacomopasquali Pro Tools 12 9 05-12-2015 04:12 AM
