Old 03-27-2016, 02:55 PM
RonnieRosolino RonnieRosolino is offline
Default WavesShell-AAX 9.6 aaxplugin Loading PROBLEM
I am having an issue with my WAVES Plug-ins loading in Pro Tools 12.4 I get this message
"The following plug-ins failed to load because they are not valid 64bit AAX plug-ins"
I have Windows 10 and Pro Tools 12.4 has anyone had this issue? PLEASE HELP! Thank you.
-RR
Pro Tools 12.4
PC - Windows 8.1
Old 03-27-2016, 03:42 PM
jjnssn jjnssn is offline
Default Re: WavesShell-AAX 9.6 aaxplugin Loading PROBLEM
Just to make sure you have your Waves Central loaded and your licenses downloaded to either a USB key or your hard drive?
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 03-27-2016, 03:46 PM
Yes sir, I did install using Waves Central.
Pro Tools 12.4
PC - Windows 8.1
Old 03-27-2016, 03:48 PM
Ok. Have you tried deleting waves caches and preferences?
Old 03-27-2016, 03:55 PM
Maybe. I did a clean uninstall. I uninstalled the plugins from waves central, uninstalled waves central, deleted all waves folders, conducted a search for waveshell and deleted them, reinstalled and still didn't work.
Pro Tools 12.4
PC - Windows 8.1
Old 03-27-2016, 04:12 PM
I am stumped! I also uninstalled Pro Tools, all my other plugins and it still doesn't work. I just purchased these and I never had Waves plugins before.
Pro Tools 12.4
PC - Windows 8.1
Old 03-27-2016, 04:19 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Did you check to make sure the Waveshell AAX 9.6 is actually in your plugin folder?
What is more relaxing then Music?
GigabyteX79-UP4 Rev 1.1
Xeon E5 2680 v.2. 10 Core cpu Windows10 v.1903
Avid HDX 2019.6 HD - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - AVID Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo - Pci-E Quad - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 03-27-2016, 04:29 PM
Waves has a folder in Program Files (x86) with the Waveshell AAX 9.6 plugin in it but it is not located in the Pro Tools Plugin Folder.
Pro Tools 12.4
PC - Windows 8.1
Old 03-27-2016, 04:57 PM
john1192 john1192 is offline
as ABC said .. the Waveshell should be in your Plugins folder .. drag and Drop that sucker in there ... should work ..
hope it works for you
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 03-27-2016, 05:03 PM
How would I go about doing that? I just want to make sure I put the correct file in the right spot. Thank you.
Pro Tools 12.4
PC - Windows 8.1
WavesShell-AAX 9.6 aaxplugin Loading PROBLEM RonnieRosolino AAX Plug-ins 3 03-28-2016 06:55 AM
Kontakt 5.aaxplugin won't work Ferrante Pro Tools 10 1 04-25-2015 04:15 AM
How can I find Kontakt 5.aaxplugin AR Studios AAX Plug-ins 4 02-07-2015 02:19 AM
PT 10 stops loading at "VariFi.aaxplugin" Soul El Windows 55 02-24-2013 08:55 PM
Mixer.aaxplugin _10.1.2 ???? onepercentfree Pro Tools 10 2 04-11-2012 04:25 PM
