Old 11-24-2015, 03:31 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Save Session Copy doesn't copy all files within the bin anymore
Just wondering whether it's just me or whether it's a Pro Tools bug (might be called a feature?).
When I create a session copy in PT HD 12.3, it doesn't copy all the audio files in my bin anymore. Only the files present on a track. This was not the case in PT 11 using the exact same settings. The option 'Selected Tracks Only' is turned off. I can do any sort of combination of settings but the session copy only copies the files on a track.
Anyone else getting this?
I'm testing this by creating a 1 track session, render 2 audio files, place one of them on the timeline and leave the other in the bin/clip list.
I couldn't find any mention of this in the readme docs. Am I missing something?
Old 11-24-2015, 07:29 AM
Eric Lambert's Avatar
Default Re: Save Session Copy doesn't copy all files within the bin anymore
When saving the session copy did you click the include audio checkbox in the initial dialogue window?
Old 11-24-2015, 09:47 AM
john1192 john1192 is offline
so only the Main Playlist is coming over ... i will see what i find here ...
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 11-24-2015, 09:54 AM
ok .. so i did the Save Copy IN .. checked the box for audio files, left Main and Selected Tracks Not Checked ..
it brought all the files BUT One .. the parent file is there but one of the Daughter Files was not BUT when i open the NEw Session the parent is missing and the daughter is there ... weird behavior .. should be identical ... another bug ??
Old 11-24-2015, 11:16 AM
Farhoof's Avatar
Yep, include audio, nothing else is checked. (There is no combination of checkmarks to fix the issue.)
Can you generate a tone, remove it from the track so it's only in your clip list, and make a session copy? (maybe delete the track to clear your undo queue). In my case the generated clip is gone altogether.
It seems the 'save copy in' function is ignoring unused clips, but doesn't provide the option to include them.
Old 11-25-2015, 06:15 AM
Farhoof's Avatar
Still the same using PT 12.3.1 now.
Old 11-25-2015, 07:32 AM
That's not good. You want all relevant audio to come into the copied session.
I'll have to check our machines today to see if this behavior is repeatable.
Old 11-25-2015, 08:43 AM
cj.allen321 cj.allen321 is offline
I'm also experiencing this too, just tested and only audio on tracks is included when Saving Copy In and including "all" audio files.
This is a definite change in functionality as you used to have to use "select unused" from the clips list menu on the copy, to clean things up.
Chris.
Chris Allen
Lecturer / Instructor / Assessor, B.Sc. (Honours) Music Technology
Middlesbrough College,
Dock Street,
Middlesbrough.
TS2 1AD
http://www.c-allen.co.uk
http://www.teesmusictech.co.uk
http://www.ironopolisrecords.co.uk/
cj.allen@mbro.ac.uk
chris@c-allen.co.uk
Old 11-25-2015, 03:37 PM
weezul weezul is offline
dangerous... although the only time i use 'Save Copy As' is to do exactly that, prune the files. one to keep in mind, thanks!
http://www.liamgaughan.com
Old 11-26-2015, 05:59 AM
Drew Mazurek's Avatar
This has been logged with Avid.
www.drewmazurek.com
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
"Save Session Copy In" still misses files. Wilbur Pro Tools TDM Systems (Mac) 1 06-20-2005 01:18 PM
PC Save Session Copy In 5.0 BWF files? Andrew B75 Post - Surround - Video 1 10-09-2004 12:20 PM
save session copy in doesn't work access privilege paapje Pro Tools TDM Systems (Mac) 2 06-01-2004 03:03 PM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
