Old 10-24-2013, 04:43 AM
WADEAL WADEAL is offline
Default Pro Tools 10 Won't Load (procedure entry error)
I have an Eleven Rack and it ran happily with Pro Tools LE8 on Vista.
I decided to upgrade and got a copy of Windows 7 and Pro Tools 10 to get the full features.
Unfortunately, when I installed it I got the following message:
"The procedure entry point ?DoIt@PopupWindow@@UAE?AVVPoint@@V?$Cmn-Point@J@@ABV2 could not be located in the dynamic link library"
I have googled it and found nothing (although I have seen a number of similar posts about procedure entry point errors in Pro Tools).
Any help would be appreciated.
Old 10-24-2013, 05:33 AM
Default Re: Pro Tools 10 Won't Load (procedure entry error)
Did you install the latest drivers for the 11R?
Jack
QAPLA!
Old 10-24-2013, 06:35 AM
I was using vista but have done a clean windows 7 install. I then installed pro tools 10. I have not connected the 11 rack as the error occurs to stop pro tools opening. I have removed all traces of the pro tools 8 le that came with 11rack. So it is unlikely to be a driver error relating to the 11.
Old 10-24-2013, 07:13 AM
Are you running the installer as administrator? If so, time to post a Sandra report
Help us Help You - READ THIS Before Posting!
Old 10-24-2013, 07:22 AM
JoelG's Avatar
JoelG JoelG is offline
Also, are you installing from CD or download? I'd almost suspect an issue with the install files. Try re-downloading and installing if you downloaded.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 10-27-2013, 12:03 PM
Thanks for the help folks.
I downloaded the program again and this time it worked.
Old 10-21-2014, 12:04 AM
muffinwilly muffinwilly is offline
I have exactly the same error. win7 clean install, pro tools express 10. tried to download it 3 times, but no matter what i do, i'm getting the same error every time!!! please help!!!!
Old 02-05-2017, 11:23 AM
allegro85 allegro85 is offline
anyone have a solution yet. have completely removed all pro tools from the computer several times and installed several times and still the same entry error. even tried to install Pro Tools 8 again and same message even though that worked fine before
Old 02-05-2017, 07:40 PM
You are going about this in the wrong way. Instead of dredging up this old thread, start a brand new thread with a description of your exact issue, and complete details on your setup, including what interface, what driver and a SANDRA report if you are on a PC(check the link near the top of this page called Help Us Help You)
Old 07-25-2017, 12:14 PM
Time2paint Time2paint is offline
Default Re: Pro Tools Express 10 Won't Load (procedure entry error)
I also have this problem with the error:
?DoIt@TPopupWindow@@UAE?AVVPoint@@V?$Cmn_Point@J@@ AB
V2@@Z could not be located in the dynamic link
library DFW.dll
I have Pro Tools Express
MBox MINI -Driver seems to work
iLok (2nd gen?) -Driver seems to work
64 Bit OS
6 core processor
3.5 Ghz
16 Gig memory
Drivers seem to work okay.
We've tried uninstalling and reinstalling PT Exp &
Deleted the Digitec file as someone suggested.
Uninstalled Pro Tools First, (which I download just so I could get something done)
I would appreciate any help. Very new to ProTools -
Pro Tools Error--Procedure entry point drew3415 Windows 2 06-15-2016 04:33 PM
procedure entry error ampstudio Pro Tools M-Powered (Win) 0 11-06-2009 03:32 PM
PT7 Procedure Entry Point Error?? Eddie D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-07-2005 03:00 PM
Procedure Entry Point Error Producers Never Sleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-23-2004 08:36 AM
Procedure entry point - error Jeff B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 02-01-2004 09:57 AM
