can I use an additional monitor screen
Hello. I'm using pro tools LE with a digi 02 rack. i have a macbook pro, can i use an additional monitor screen with the macbook, one for edit window and one for mix window, and if so how can i do this? thank you.
Re: can I use an additional monitor screen
Yes of course...
Just connect a monitor via the appropriate cable/adapter to the mini display port connector on the Mac. The type you need will depend on your monitor.. Then in system preferences you will need to set the monitor to extend the desktop in stead of mirroring it.. Then just drag your windows where you want them
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Can you elaborate on this??
www.propellersound.ca |
Just plug in the second monitor and see what you get in System Preferences>Displays.. This is pretty basic stuff... Just give it a try.
He means 'System Preferences' in OSX and not Pro Tools. Just to clarify so he won't be looking in Preferences in PT.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
Thank you very much I will proceed with all of your advice.
I just got through this.
1. Save some time, get your adapter from a Mac dealer, I did find a best buy that sometimes stocked the proper cable, but I dont think this adapter lives in the PC world. its a Mini DVI to xxx, they have 3 different other ends available. I got a mini DVI to DVI, then a DVI to HDMI cable since It is going to my LCD TV. The Mac cable is only about 3", so you'll ned the second one. 2. In your Mac Book go to System Prefs, then to Display. I dont have my Mac with me at work where its all PC, but there are several tabs, look through them untill you see two monitors side by side. 3. Mac is set up to do 2 things with external displays, one is to keep one display on the main puter, and extend the virtual desktop to a second display so you can have 2 windows open. When you mouse to the selected edge, instead of stopping, it continues and your other open app or window is there. In sys prefs, you drag the external monitor to any of the edges of the main monitor to choose the edge. You could have the Mix window on one screen and the edit window in another. This works well when you are using a desk top and large monitor. But since we have dinky displays, we want the other way to use it. Check the "Mirror" box. This has nothing to do with reversing the image, it means that the external display mirrors the main (laptop) display, and there is not a second work area. Between the 2 cables, I spent about 60 bucks retail.
Woody Woodruff The Gem Theater, St Louis MI Digi 003 Rack, MOTU 828 MkIII Mac Lepoard 10.5 Duo Core2, 4G RAM Glyph GT050Quad500 PT v 7.4.2 Home DAW MBox 2 MacBook 13" 2.1GHz, 4G RAM Glyph GT050Quad500 PT v 7.4.2 (v 8 when available) |
Touch Screen Monitor S3L | pmueller | VENUE Live Sound Systems | 19 | 06-13-2016 09:53 PM |
monitor screen and cpu | redchair | General Discussion | 3 | 11-17-2009 02:09 PM |
Using 2nd Imac for 2nd screen monitor | K Roche | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-09-2009 06:23 PM |
Screen or monitor flickering | Stephanie Foxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-08-2007 01:59 PM |
flat screen monitor for G4 | gregfrey | Pro Tools TDM Systems (Mac) | 7 | 02-13-2004 06:56 AM |
