Athlon users
Is there anyone using an Athlon with a MS6167 mobo or Irongate chipset.
I have: Athlon 500 MS 6167 128mg PC100Ram Ati Rage Pro AGP card Voodoo2 Seagate Baracuda UDMA66 HD Windows 98 After installing the 001, everything looks OK. Control panel system device manager reports device working poperly, everythings OK in multimedia properties etc. Digi test passes every time. But as soon as I try using the digi drivers or running Pro Tools the system either hangs, playes a couple seconds of audio(in Sound Forge)& then crashes so badly I have to reboot or gives me the 6010 error. As far as running Pro Tools I can't even start the program(either hangs or gives 6004 error-can't accuire hardware).Although a couple times I did managed to pass the registration just to be greated with another error and Pro Tools exiting. I tried all the solutions I could think of: Format HD, clean install windows, taken all the other cards out, tried every PCI slot, Disabled UDMA66, Tried different graphics card etc. If there's anybody using the same mobo/chipset or a succesful Athlon/motherboard configuration,please let me know because this thing is driving me mad and being a student, I can't afford a new machine. |
Re: Athlon users
What all do or did you have installed in your system, as far as sound/audio cards are concerned. It sounds like you have not set the 001 one as the perferred recording and playback device, which will give you that error when you open PT( and sometimes crash). Make sure you go to the control panel, open the multimedia settings, and then select the 001 as the perferred playback, and recording device, and push apply. I hope this fixes the problem.
Christian |
Re: Athlon users
Hi Christian,
PTLE should not require that the Digi001 be selected as the preferred Multimedia playback device. Have you experienced a problem in this area? PTLE doesn't use the wave driver, but rather talks to the hardware directly. Eric Day DAE Engineer BTW, thanks for all your help on this board. It's very kind of you to share your PC knowledge with everyone. |
Re: Athlon users
Thanks for your advice crs117.
I had digi set as the preferred device but it still makes no difference. In fact, while it was set like that, it tend to bring the whole machine(graphics) down to a crawl even when using non music software(MS word). I even renamed the digi16.dll to stop the driver from loading.This sorted my graphics problem but Pro Tools still won't launch. Normaly, it would stop at the 'launching DAW' and come up with the 'error 6004'. By the way, there are no other sound cards in my system and I tried running 001 in my dad's PC (PII 400, 440BX). It works like a dream. Each PCI slot is being used, there is a Yamaha SW1000 installed and there is no conflicts at all, so i'm shure the 001 is ok. <BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by crs117: What all do or did you have installed in your system, as far as sound/audio cards are concerned. It sounds like you have not set the 001 one as the perferred recording and playback device, which will give you that error when you open PT( and sometimes crash). Make sure you go to the control panel, open the multimedia settings, and then select the 001 as the perferred playback, and recording device, and push apply. I hope this fixes the problem. Christian<HR></BLOCKQUOTE> |
Re: Athlon users
Well actually Eric,
Yes my computer has a problem if the 001 is not set as the perferred multimedia device. The first time I ran into this i simply changed it, and i have had no problems since. I did change it back to experiment with running a final wave file through my SB live (to see if there was an audible difference in audio quality between it and my 001), but before i could open pro tools and work in it again, i had to reset the 001 as the perferred device. I am not really having problems, but i hope this info may help out. Here is my system Dell XPS 333 (heavily modified) 440 LX (cannot change north and south bridge multipliers) 66 FSB (it was overclocked before my 001, but didnt want to fry it with out of spec PCI) SB live (all midi disabled in PT config) V550 TNT by diamond 192 megs of ram 56k modem (disabled in PT config) 8.4 gig 5500 Rpm drive 20 gig 7200 rpm drive 2x dvd drive 4x2x2 CD-RW drive (old school mitsubishi) Christian |
Re: Athlon users
Hello Eric, 11 again.
I see you've been pretty quiet on the whole subject, but can't you at least give us an insight if there are any tests being done/problems encountered as far as athlon is concerned. Being a student,I don't want to be getting a new machine(this one is only 4 months old)unless I really have to. It would help people like me decide if they should wait a little longer or forget the whole thing and go for a PIII/Mac. Thanks, 11. <BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by Digi Engineering: Hi Christian, PTLE should not require that the Digi001 be selected as the preferred Multimedia playback device. Have you experienced a problem in this area? PTLE doesn't use the wave driver, but rather talks to the hardware directly. Eric Day DAE Engineer BTW, thanks for all your help on this board. It's very kind of you to share your PC knowledge with everyone.<HR></BLOCKQUOTE> |
Pro tools Athlon users | sampie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-10-2006 05:12 PM |
A must read for Athlon 64 users!!!! | Jayman#9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-03-2004 06:55 AM |
athlon xp users | rocman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-25-2002 01:34 PM |
HIGH CPU IDLE. ATHLON USERS?? | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-05-2001 12:30 AM |
Athlon 1.4ghz is out. Can someone give a successful Athlon system specs? | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-29-2001 07:00 AM |
