  #21
Old 01-20-2014, 03:46 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default Re: EUCON/EuControl 3.1 available
I just got the Artist Mix.I noticed it doesn't seem to work unless I turn the unit on before I start the computer..Is that the same thing you guys find
  #22
Old 01-20-2014, 03:55 PM
Southsidemusic's Avatar
Hi
We do the oposite. First turn on the Mac - Eucon (do not use auto start) then after "E" stop spinning we start the 4 units we have and always picks them up within seconds
Eucon 3.1 and no issues at all. We have been lucky to have our smaller room where they reside working from the start on OSX 10.8.5 and Macbook Pro Retina.
Best of luck
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #23
Old 01-20-2014, 08:38 PM
mikeyman's Avatar
that's strange wonder why my unit won't hook up to PT's if the computer is already on..First I loaded the disk it came with and it seemed to work good and turned on automaticly by itself I think when the PT's booted up.The next day I got all kinds of error messages so I loaded in 3.1 and now it only will hook to PT's if I turn it on before I start the computer.
  #24
Old 01-27-2014, 10:14 PM
TAMBOR TAMBOR is offline
Originally Posted by kdarbyshirebryant View Post
My workaround is as follows (at your own risk - take a backup first...and check you can restore it!)
What a brilliant solution. To be able to tinker with the drivers and such. How did you figure this out? Do you have some inside info?
Tom
  #25
Old 01-28-2014, 06:45 PM
HowlingWolfStudio HowlingWolfStudio is offline
I've had nothing but trouble with 3.1 for PC. (Not showing up, showing up after I restart Pro Tools, power cycling the Mix and Transport, etc)
I uninstalled it and put 3.0.1 on, and it's running flawlessly. Something is definitely up with 3.1. At least on the Windows side, can't speak for Mac any longer.
  #26
Old 01-29-2014, 07:55 AM
Artist PM's Avatar
Artist PM Artist PM is offline
We will solve driver signing in an imminent release.
JC
  #27
Old 02-11-2014, 11:42 AM
frodi frodi is offline
I have just installed version 3.1 on my mavericks system, but every time i try to open the EuControl software i get an unexpected quit. Can anyone help me?
This is the error:
Process: EuControl [280]
Path: /Applications/Euphonix/EuControl.app/Contents/MacOS/EuControl
Identifier: com.Euphonix.EuControl
Version: 3.1.0 (7778271)
Code Type: X86 (Native)
Parent Process: launchd [154]
Responsible: EuControl [280]
User ID: 501
Date/Time: 2014-02-11 19:17:34.791 +0000
OS Version: Mac OS X 10.9.1 (13B42)
Report Version: 11
Anonymous UUID: 5EE36146-41BD-C66A-7F2B-7741C1638F47
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
  #28
Old 02-14-2014, 07:54 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Yes, same problem.
And I have to restart my imac every time it goes to sleep to have my eucon devices working.
  #29
Old 02-28-2014, 01:49 AM
bcslaam bcslaam is offline
I have artist transport with eucontrol 3.1 with new firmware 1.6, windows 8 pro 64bit, PT11.1.2hd all freshly installed (including os). I bought intel pro1000 pcie nics and a deicated unmanaged switch
I dont have the driver signing problem (especially since I disabled driver signing), eucontrol sees my transport and daw and there are drivers present in device manager but im getting
'Protools is incompatible with this Eucon personality" when I try to enable it in protools.
Also eucontrol doesnt present all the usual commands for protools even if I was to try and make my own layout. I know its not the hardware because before this new fresh os install it was working with 3.01. All the trouble started as soon as I installed 3.1
I have tried everything!!
Uninstalled 3.1, re-installed, downgraded firmware to 1.5 and installed 3.01, removed .cfg file, different boot up power on orders, fixed lan, dedicated lan, dhcp on and off all the workarounds found in duc and google and nothing will stop this error.
This totally sucks avid, waisted too much of my time on this.
Is there a way to force the personality? Can you upload one for windows?
  #30
Old 02-28-2014, 01:57 AM
mikeyman's Avatar
Originally Posted by Xill View Post
Yes, same problem.
well your recording computer should be set to '' sleep never ''just saying
EUCON/EuControl 3.1 Now Available Artist PM Technical Alerts 0 12-13-2013 06:11 PM
Updated Eucontrol to 2.7 and upgraded to Mountain Lion 10.8.2. Eucon now broken. Focuret macOS 0 03-08-2013 09:21 PM
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 02:35 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
