Old 03-29-2017, 04:01 PM
leftalive leftalive is offline
Default A few Windows questions (from a long time Mac user...)
Just switched over to a Custom PC workstation running PT 12.4 under Win 10 Pro, and I haven't used Windows in probably 17 years. A couple of quick questions (as the search function seems a little wonky today):
1 Does the Pro Tools 12 app itself store core plugins within the app the way it does on MacOS? On Mac I can right click on the PT app - show package contents - and delete the core plugins I don't use (like Maxim, BF76, etc) so that they don't load by default. Is there a similar method for Windows? I found the Factory Content folder, which contained IO Settings, Fade Presets, etc, but no core plugins.
2 I'm assuming I can safely uninstall the Avid HD Driver (x64) if I'm running a native rig, yeah?
3 And what is this 'Avid Effects' that shows up in my programs list? It has a plugin icon... don't know that I've ever seen this on Mac. Safe to delete, or no?
Thanks in advance, guys. It's been a while since I felt like a newb to this degree.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 03-29-2017, 04:37 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: A few Windows questions (from a long time Mac user...)
I believe the stock plug-ins are in the Programs Folder.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-29-2017, 07:04 PM
Indeed, things are a tad different.
Plugins are here; C:>Program files>common Files>Avid>Audio
Re the HD driver, I don't know but I would leave it as it does no harm(uses no system resources). The one important detail is this; If/when you uninstall Pro Tools(which is done from Control Panel>Remove a Program), there will be 3 options: Remove pro tools ONLY, remove Pro tools AND the HD Driver, Remove pro tools, HD driver, prefs and database. NEVER choose option 1(IOW, DO remove the HD driver whenever you uninstall for any reason)
as for #3, I'm not sure exactly what it refers to so I would leave it.
Old 03-30-2017, 01:24 AM
take77 take77 is offline
Avid Effects are installed by the main installer along with the main app.
These are all your stock Avid effects plugin's like the BF76, etc.
It MIGHT include the system plugin's like HEAT, etc. (I'm not sure).
These do not include the the AIR effects or instruments which are installed via separate installers.
You can go to the Audio folder that albee1952 pointed to and there is a "Plug-ins (Unused)" folder.
Any plugins you do not wish to load may be moved to that folder.
This way you are not inadvertently uninstalling any plugins you might want to use like Channel Strip, etc.
The HD driver is required to be installed first before running the 12.7.1 installer (if the HD driver has been removed).
Otherwise, Windows installation of 12.7.1 will not complete.
Just for future ref!
Old 03-30-2017, 07:56 AM
TOM@METRO's Avatar
If you're new to Windows, it's best to leave everything intact until you know you have a working system. Then, removing things one by one will let you know if you've gone to far.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-30-2017, 02:26 PM
That's basically what I'm doing, yeah. Been a fairly pleasant experience, thus far.
Thanks guys.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
Pro Tools 12.4
A loaf of bread
A stick of butter
Old 03-31-2017, 07:40 AM
TOM@METRO's Avatar
Thanks guys.
Good to hear.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Long Time PT User; Brand New Rig ohmy Getting Started 3 08-13-2013 06:56 AM
Calibration issue (long time user) ChrisSnyder Pro Tools TDM Systems (Mac) 3 06-20-2013 02:56 PM
New mac user - long time PC user. Need to install on Mac. SixChurchStreet Pro Tools M-Powered (Mac) 0 04-21-2010 05:54 AM
Long time 001 user with upgrade questions Folkcafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-23-2007 07:30 PM
Long time user, 1st post Greg Rogers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-11-2006 09:55 AM
