  #31
Old 01-10-2010, 05:02 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Re: Mac G4 1.25 Single Processor, AM3 card, can't find the card...
It seems to be your Mac does see the AM III, as I can see identical info: my Card name is also pci11af,ee40, my Card vendor is also 11AF, but the Card revision is not the same, I have 0011, you have 17, so I suppose your AMIII card is newer then mine.
I read in your previous post you first installed SD II 2.8.3, then DAE-DSI 5.0. I have never done that, I had PT 5.1.1 installed, I copied the SD II-application from another Mac (a 9600), launched it and it did work. So maybe you need to reinstall OS 9.2.2 (just to get rid of all Digidesign stuff), then install DAE + DSI 5.0 and then copy the SDII-application from another Mac (thus not installing it from the installer diks). Maybe this helps...
Anyway, I'm not sure it is enough to just install DAE + DSI 5.0, because I have installed:
Extensions:
Digidesign Direct I/O - v. 5.1.1
Digidesign DSP Manager - v. 5.1.1
Digidesign Stream Manager - v. 5.1.1
DigiSystem INIT - v. 5.1.1
Control Panels:
Digidesign - v. 5.1.1
DAE Folder:
DAE - v. 5.1.1cs1
Maybe you need one ore more of them (5.0 versions) + DAE/DSI 5.0 to get it to work
If you mail me privately (go to my web site for the address), I can try to send them to you...
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
  #32
Old 01-13-2010, 09:54 PM
DJTempo DJTempo is offline
OK, to try and eliminate any variables, I went and purchased another AMIII card (off eBay). Seems to be the same card, shows up in the System Info on the Mac identically, and is not seen by my copy of Sound Designer 2.8.3. Same problem as before.
Ho hum.
My question to anyone who might be reading this sorry thread: has anyone out there ever used SD 2.8.3 with an AMIII card on a B&W G4? Getting down to the basics, but seemed like an appropriate question to ask.
Chip
  #33
Old 01-14-2010, 05:07 AM
I have never personally seen a B&W G4 with SD 2.8.3 and a AMIII, but I have it working on a MDD G4 Dual 1.25 GHz, this is the same machine as your G4 1.25 GHz Single Processor and these machines are much more recent then a B&W G4. So I suppose it should work on an older B&W G4 too (a B&W G4 has 733 MHz max.)
Anyway, did you see the SD II Support pages on http://www.digidesign.com/index.cfm?...1&queryString= ?
There you can read this:
Can't select a Peripheral in Sound Designer II Hardware Setup window
  • Corrupted DigiSetup file. (Quit SDII and delete the DigiSetup file from the System Folder. Restart Mac, boot SDII and open Hardware Setup to select peripheral.)
  • Multiple DigiSystem INITs in the System Folder.
Btw, did you already try to use DAE & DSI 5.1 or higher on you MDD G4? I use DAE & DSI 5.1.1 and it really does work with SD II 2.8.3 (you can downlaod them at http://archive.digidesign.com/download/daedsi/ )
If you have a B&W G4 with PCI graphics, you can read on that same download page:
  • DSI 5.0.1cs4 Update (For Macintosh)
    Fixes for Pro Tools TDM or LE Systems Using 'Blue & White' G3 or G4 w/PCI graphics (only for these systems)
FWIW, I still think for both your B&W G4 and MDD G4 it is a software problem and not a hardware problem...
Marc Schellekens
  #34
Old 01-21-2010, 04:21 PM
Well gang... I had to get something running for all this back-and-forth and buying new CPU's and new AM3 cards, and all this... and I finally have a 450MHz Blue & White G3 running Sound Designer 2.8.3.
I seem to have no trouble on G3's or earlier, G4's and I have the aforementioned problem.
I do not know what to do with the 1.25 GHz G4.
The G3 needed DSI 5.0. I started with 3.4.2 and SD started saying "you need proper Digidesign hardware...".
I have an Atto SCSI-3 card, AND a 150GB FIREWIRE (?!!!) drive hooked up, and they both behave normally under SD 2.8.3.
I'm tempted to do a little tinkering, trying to record to the Firewire drive to see if it actually works. (I can see it on the desktop, but only got so far as to play a couple songs with SD before I had to give up for the evening).
I'm going to go over all these posts with a fine toothed comb, and might try the 1.25 again if I derive anything I hadn't already tried.
In the end... THANK YOU to those who tried to help out.
Chip
  #35
Old 01-22-2010, 06:29 AM
Whelp, taking a hint from the last post, I went and found DAE/DSI 5.1.1. Installed, rebooted... and it's working. I hadn't tried anything higher than 5.0 because they stopped mentioning the AM3 and/or SD in the descriptions. All the descriptions look like they work with ProTools. I think I hadn't gone any higher than 5.0 before.
So, now... I have about 3 months worth of audio projects to catch up on.
While I'm at it, does anyone know of a faster machine (than the 1.25) that will still run SD using the AM3 card?
  #36
Old 01-22-2010, 07:39 PM
milesofwire milesofwire is offline
I knew that was it.
You have the fastest processor that was ever ment to run OS9, a dual won't have any effect since 9 only will use only one.
  #37
Old 01-23-2010, 05:44 AM
In post 8 of this thread I wrote ( more then a month ago):
Originally Posted by Delta Music Belgium View Post
- with OS 9.2.2 (and the Expansion Chassis with Mix hardware is switched off), I use Sounddesigner 2.8.3 with AudioMedia III, it works like a charm (using the same DAE 5.1.1 + DSI 5.1)
In post 14 of this thread I wrote:
But I can give you a list of Digidesign OS 9 Extensions/Control Panels that I use for SoundDesigner II 2.8.3:
Extensions:
Control Panels:
DAE Folder:
DAE - v. 5.1.1cs1
As you can see it is the standard installation for PT 5.1.1 and this works perfect with SoundDesigner II 2.8.3 + the AudioMedia III card.
In post 19 of this thread I wrote:
I use DAE + DSI 5.1.1 and this works like a charm, you could download DAE + DSI 5.1.1 here
In post 31 of this thread I wrote (I even offered to send you DAE + DSI 5.1.1):
Extensions:
Control Panels:
DAE Folder:
DAE - v. 5.1.1cs1
But for some strange reason you never wanted to listen to me...
But now I'm happy you finally took up my word and installed DAE & DSI 5.1.1! So all the time I did spend here trying to help you out wasn't wasted (sometimes I felt quite frustrated)
Btw, I'm a Pro Tools Support Engineer since 1995 and I installed and supported hundreds of Pro Tools rigs, starting from Nubus until today, including lots of G3's and G4's (with or without SD II). I also used and owned all of these systems myself, even until today I have a 9600, a 9600 with G3 CPU upgrade, a G4 Dual 1.25, a G4 Dual 1.25 FW800 and a G5 Dual 2.0, all of them running some type of Digidesign soft & hardware.
Anyway, I wish you all the best with SD II 2.8.3, IMHO the best 2-track editor ever made!
Marc Schellekens
  #38
Old 01-23-2010, 05:49 AM
Originally Posted by milesofwire View Post
I knew that was it.
Maybe you knew it, but you never spoke about DAE & DSI 5.1.1 in this thread
Btw, OS 9 can use a G4 dual processor without a problem, fe. Altivec compatible software such as Photoshop or Logic Audio 4.x.
The point is Digidesign software has a problem with dual processors on OS 9, for a Dual G4 + OS 9.2.2 you need to install the extension 'ApplePCI', this extension in fact disables the 2nd processor.
So, DJTempo, for SD II there is no need to go to a Dual G4 indeed...
Marc Schellekens
  #39
Old 01-23-2010, 06:06 AM
I mentioned it in my emails to the OP, I have done alot of work for this guy to get this working outside of this thread, you don't have be rude a jump to conclusions.
  #40
Old 01-23-2010, 09:11 AM
I'm not rude at all, based on this thread my conclusions (if any, I use the word 'maybe' in my sentence) are correct, you never talked about the DAE/DSI issue, I can't know you did some helping behind the scene...
But I can conclude out of this DJTempo didn't want to listen to you either
Btw, there is a behind the sentence in my previous mail, I don't think that's being rude, I think that's being plain friendly
Anyway, I didn't want to be rude in any way, I'm sorry you see it that way...
Marc Schellekens
HTML code is On
Just want to buy a single HDX card ? Firechild Pro Tools HDX & HD Native Systems (Mac) 4 11-28-2011 10:52 AM
Single slot monitor card? efisch Post - Surround - Video 7 09-25-2011 10:41 AM
ATTO Single SCSI Card and a G4 - Possible?? worldsend Pro Tools TDM Systems (Mac) 2 11-16-2005 11:22 PM
G4 533 Single Mix Plus PT 5.01 Doesn't see Mix farm card Count Zero Pro Tools TDM Systems (Mac) 6 02-17-2001 09:47 AM
Can I use an 888 and 1622 on a single Mix Card ? Evolution Pro Tools TDM Systems (Mac) 1 02-27-2000 07:13 PM
