Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-28-2020, 08:39 PM
fsavell fsavell is offline
Default Hardware Inserts not compensating correctly (ADC)
Been a long time since I've had any HW insert/ADC issues, but since upgrading to 2020.3 my HW inserts sometimes aren't being correctly delayed/compensated.
I often run outboard compressors in parallel especially on drums and master. Its super obvious when the ADC isn't working on these correctly due to the comb-filtering. I've found its usually only 1 sample out. I had a session the other day which would flip this every time I opened the session. If I manually adjusted the delay comp on the master aux to 1, it would need to go back to 0 the next time it was opened.
So essentially Hardware delay comp is buggy in 2020.3. Just throwing this out there to see if anyone else is experiencing this?
Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2
Old 04-29-2020, 06:50 AM
Emi's Avatar
Emi Emi is offline
Default Re: Hardware Inserts not compensating correctly (ADC)
A scream to Avid to introduce ping delay compensation. But they won’t introduce because the “big brother” hdx wouldn’t sell...
I see this issue when u change sample rates. What I usually do is relaunch PT and then it compensates “ok”
Even reaper is more accurate at this and PT is the golden industry standard... bla bla bla
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 04-29-2020, 10:59 AM
john1192 john1192 is offline
hmmm ... i was told by avid years ago that they could NOT make the Ping Feature work with the current Architecure of PT ... no other explanation ..
i have been screaming about this for years ... the Hardware INsert Delay used to work perfectly .. now it is different everytime i try it .. i hear you 150% ... this needs to be FIXED ASAP ... or lose the feature all together .. this half-assed version sucks
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-29-2020, 11:09 AM
Emi's Avatar
Emi Emi is offline
If they loose the feature altogether I’m forced to loose PT as well. I insert hardware on daily bases.
Old 04-29-2020, 11:31 AM
JFreak's Avatar
JFreak JFreak is offline
If this is a real issue for you then please open a support case with Avid Support -- that is your "money" towards Avid. Otherwise they have no clue.
Janne
Old 04-29-2020, 12:03 PM
hi Janne, i brought this up to Avid, opened up a ticket for this and the answer given to me by Avid is what i posted above ... they told me the Ping Feature could not be done !!! so, i beleive them as the way it is it is not working well !!!
but it has Worked Perfectly, in the past, so there should be a way to replicate .. i had a sheet with each sample offset for each sample rate .. 29 samples is what it was PERIOD for my Lynx Aurora with Lynx PCIe card .. i do not have that system anymore, so can no longer test ..
i have logic here as well and can use the png function to get me the Numbers ... then try and place those in PT and see ... just need to dig up a cable as my Babyface Pro 3/4 inputs are 1/4" ... i will come back and report what i find ..
thx for keeping this issue alive !!!
NOTE: after trying this in Logic .. i got "+1" sample latency after the Ping through a DBX160A ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-29-2020, 12:38 PM
Emi's Avatar
Emi Emi is offline
cheers john
I used reaper to give me the numbers but were wrong. So I suspect every daw will give a different number. The best way is to do a hardware loop (plug a cable from output to input) and measure the samples.
Another thing is why, WHY in the world doesn’t Avid let you put samples in the I/O hardware insert delay in place of ms, which is inaccurate.
Old 04-29-2020, 01:49 PM
i know this is not correct for my babyface ... something is weird ... and this interface does not really have an easy way to test inserts as there are not enough ins and outs to isolate them .. even with panning .. ha
i hear you oud and clear !!! WHY
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Profile wont save inserts correctly JohnEvans VENUE Live Sound Systems 14 02-26-2015 04:06 PM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Hardware Inserts CosmicJunkie Pro Tools TDM Systems (Mac) 1 11-20-2007 03:12 AM
hardware inserts.. Vini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-07-2002 07:29 PM
Why hardware inserts drenched 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-10-2002 12:28 AM
