problem with opening session please help!!
when i try to open a session,after loading all audio files+dae registered files+plugins before he opens the PT Interface i get a wierd messege"there is not enough memory while translating paths".I have a TDM system With 882,core,mixplus,2farm.i have 80000k allocated to PT&80000 to DEA.
any ideas? [img]images/icons/confused.gif[/img] |
Re: problem with opening session please help!!
strange message...when all else fails, trash your digi(dae) prefs and reboot.
good luck! |
Try the following:
-Increase your DAE Preferred memory to 100000k (100MB). Leave the Minimum size set at default. -Remove the I/O Settings files from the System Folder>DAE Folder>I/O Settings folder (no need to trash them yet so just place them on the Desktop for now) and attempt to open the session. If the above does not help, you may be dealing with a corrupt session. Create a new session, use the File>Import Tracks command to transfer the tracks into the new session file and see if the eror persists. Brent |
thanks brent, i tried what you suggested and it stiil gives me the same messege.
i tried to open a new session and import tracks but when i had to show him where the tracks are i got thrown out of PT and had to restart. my luck that i had a session backup witch solved the problem. thank alot brent/digidesign. [img]images/icons/smile.gif[/img] |
Problem Opening A Session! HELP!! | sant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-11-2011 11:24 PM |
7.4 Opening New Session Problem | RichrdC | Pro Tools M-Powered (Win) | 7 | 04-04-2009 04:09 PM |
opening session problem | -wem- | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-28-2008 03:53 AM |
Problem Opening PT Session | ardy | Tips & Tricks | 9 | 10-17-2006 10:31 AM |
Problem opening PT 3.2 session | Magnetic | Pro Tools TDM Systems (Mac) | 1 | 05-03-2001 07:16 AM |
