Old 10-15-2003, 09:45 AM
Smithtrax Smithtrax is offline
Default DSP Usage?
I am using a Mix 24|plus system running ProTools 6.1 on a G4/Dual 1Ghz machine. When you pull up System Usage and it gives you how much DSP is being used, I have 2 or 3 bars open on both my core and farm cards and when I go to add a plug-in, it tells me there is not enough free DSP along with an error code. When I click on any of the open bars it goes read and says "allocated". If I boot back into OS9 and run ProTools 5 and bring up the system usage, I am able to completely fill up the DSP usage with pluggins without any problems. Is this an OS X issue, ProTools 6 issue or am I missing something? I have trashed prefs / rebooted and looked for every possible setting and I can't figure out what is up. Any suggestions would be helpful!
Thanx!
[email protected]
Old 10-15-2003, 02:13 PM
DigiTechSupt's Avatar
Default Re: DSP Usage?
Hello,
Some plug-ins require SRAM chips. Plug-ins like Reverbs, Multiffects, etc will require SRAM chips to run. Each Mix card has 6 DSP chips per card. Of these 6 chips 3 can be used for the above mentioned or similiar (reverb, mutli-effect) plug-ins. The other 3 chips can be used for compressors, eqs, etc. If you would like to confirm what plug-ins require SRAM chips, check System Usage from the Windows menu in Pro Tools. SRAM chips are the 1st, 4th and 5th chips on all Mix cards. Try instantiating a DigiRack compressor and see if it will instantiate on one of the chips that are not working. Mostlikely the plug-in you are trying to instantiate requires an SRAM chip and there is none available.
Mike
Avid Audio Tech Support
Support FAQ
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Help understanding CPU Usage, RAM, Disk Usage... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-03-2006 07:41 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
CPU usage Room24Prod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-16-2004 06:20 PM
5.3.3 on XP Pro and CPU usage Ken P Pro Tools TDM Systems (Win) 0 09-03-2004 10:19 AM
