Old 08-17-2008, 01:19 PM
Artfuldodger Artfuldodger is offline
Default Configuring help
When I access the help options within pro-tools it tells me that it can't find the pdf's.
Is there an ini/xml file or system setup file that I can use to tell pro-tools where to find the help pdf's?
I ran the documentation installer and did not recieve any error messages.
Old 08-17-2008, 04:40 PM
The Night Train The Night Train is offline
Default
If your running Pro Tools version 7.3 specifically, documentation is not available from the help menu. After running the documentation installer, you should be able to access it from the start menu..
Start > All Programs > Digidesign > Documentation
configuring new PC for Pro tools beatlloydy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-13-2011 05:05 AM
configuring I/O with Mbox2? alexbutterfield Tips & Tricks 1 02-23-2006 07:08 PM
configuring AMS Dopamine MIDI 3 02-18-2006 02:21 PM
Set Up / Configuring help Kawi Tips & Tricks 3 06-23-2005 09:15 PM
help configuring studio gira29 General Discussion 0 11-27-2003 02:37 PM
