#1271
Re: Best Core 2 Series Desktops-Results and Specs
yeah i didn't get a whole lot more either goin' to 4gb. but you're right, it will help with VI's.
did you get your ram to clock at 1333???
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#1272
no.
i will have to dig into the manual for that one. 1066 is the fastest setting in the bios. i just set it to auto. i'll try right now and see if it seems better with auto, or 1066. ----------------------------------------- just ran the test again with 4gb ram while monitoring the temps, and my mobo temp went up to 45 and i got a warning. i just took out the 2 new gigs and it stayed at 32. why is this ram running so hottttt???????? |
#1273
okay.
with 4 gb ram installed running cpu maxed out with 263 dverbs @ 6 minutes in cpu temp is 48 mb temp is 41 @7 min mb temp went up to 42 @10 min cpu temp went to 49 @ 12 min cpu 49 mb 42 @ 16 min cpu 49 mb 43. okay. i can see where this is going. i am using pc probe II. not sure if any of this really matters. just saying that the ram is running hot temps go back to normal after i quit pro tools. do you think this will ever be a problem? |
#1274
well that is with your system runnin' flat out for the dverb test tho. i stopped my test after 5 mins so i'm not sure how hot my rig would have gotten had i run my test that long. my cpu temps did get up to 49-50 within the 5 mins tho. don't know what my mobo temp was. i'd say load up one of your regular sessions and see how temps look with that also.
i did set my cpu voltage and dram voltage lower than the specs after my test so things would run cooler tho. but i played with things long enough to see if they were gonna be stable. right now i'm playin' with some OC'g and temps on the mobo and cpu are runnin' higher...not by a whole lot but higher. good luck with gettin' your ram dialed in to 1333. don't know why you are not seein' that option.
#1275
hey ivan, have you checked and updated your bios if necessary, that is also a possibility for your mb not allowing your ram to go to 1333????? just a thought.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#1276
and make sure you have your FSB freq and FSB strap set correctly. the settings have a 'direct' correlation to your available ram settings. what 3 options are you seein' for DRAM freq???
#1277
just thought i'd share my OC'g results with the rest of the Q6600 folks on here
i think i tested about 20-25 different bios setups and this is what ended up bein' the best settin' for me (Q6600 and ASUS P5K Deluxe Wifi w/bios 0603) for a 2.8ghz FSB Freq. for whatever reason i didn't want to OC too much. so this was the number i picked outta the air (or somewhere !!) FSB strap 266 FSB freq 400 cpu multiplier 7 DRAM freq 1003 (under clocked my 1066 ram) command rate 2t timings 5-5-5-15 tRFC 42 'Ai Transction booster'** ENABLED Boost level 2 (gives me a tRD of 6) **also known as tRD or performance level, depends on mobo results provided from SANDRA tests... memory latency 72ns memory bandwidth 7532mb and all of this was achieved WITHOUT touchin' ANY voltages!!! my CORETEMP idles are 37 39 32 35 with my cpu fan profile setting at 'disabled'. chasis fans profile is set to enabled. my rig is wicked crisp!!! regardin' the real world application of PTLE 7.4cs4, i picked up an additional and solid 54 dverbs ([email protected]/[email protected]). and this was still havin' ALL my plugins loaded (yep still too lazy to remove 'em!!! but i got close!!! ) temps on full-load were 51 50 46 47 i played with all FSB straps, FSB freq, and multipliers up to and at the 2.8ghz clock. this one delivered the most bandwidth and the 3rd best latency score. one of my goals was to not mess with cpu or dram voltages which i set manually, others are on 'auto'. and i did not wanna OC memory. thus my 'underclock' because of the choices that the strap and freq yielded me. so i could easily live with 1003 as opposed to 1066 especially since the 1066 did not get me better bandwidth when combined with the selected settings in the strap and freq. i also tested with underclocked ram @800 with timings of 4-4-4-12. scores and latency were good but bandwidth took the hit most noticably. i used SANDRA (latest version), MEMSET 3.4, CPU-Z, and HARDWARE MONITOR. for my benchmark test i scanned a 4.5g folder with SPYSWEEPER AV. this setup did it in elapsed time of 3m:11secs whereas the setup with the worst score was 4:06. and of course this was done on my non-PTLE partition since SPYSWEEPER doesn't play nice with the onboard F/W of this mobo from a PTLE perspective, i gotta believe the fact that havin' my latency (between NorthBridge and ram) dialed in like i got it 'directly' aids PTLE's performance greatly (21% increase in dverb score ). now the extra bandwidth is certainly a plus but since our most dreaded errors usually have to do with latency of some sort then i 'think' this is a key. but then again openin' up the FSB freq to 400 (deliverin' a rated FSB of 1600) ain't shabby either. the fact that my bandwidth efficiency wasn't that great, only 46% (some of the result of underclockin' the ram), but these results were still produced, again ain't too shabby. even with the SSAV tests, as long as latency scores were close, i could sacrifice bandwidth and still only have a difference of about 3 secs in scores. maybe when i've recouped from this past round of testin' i'll do a DVERB test with a setup with close to the same latency score but with a slower FSB (350 FSB @8x, yieldin' a rated FSB of 1400) and see what i get. but you know i'll find out that it's latency, FSB speed and bandwidth!!! but the more i think about it, the order will probably be rated FSB speed, latency, and bandwidth!! anyway, for those lookin' to OC a bit, here ya go!!! hope it can be of some help. sunburst and blade, i blame you cats for my need to know!!!
#1278
That's some pretty impressive stuff there Mykhal, especially without touching any voltages.
Is that memory score for read, write or copy? |
#1279
Doing Dverb test and can't make more than 32 tracks...CPU is about 60% only. What do I do next? Test tone is solid for all 5 min.
#1280
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
