Why do I get this "error" ALL THE TIME?
My first post here, so if I´m the wrong forum section I apologize.
Running PT 7.1 LE with Mbox 2 on a Quad 2,67Ghz with 4GB RAM and Win XP Home. I get the "Increase buffer size"-message all the time, and I just don't get it. I have a pretty powerful machine and I have hardly any programs running in the background. No internet connection, no antivirus programs or anyting. If you check the attached image, in this project I´m just recording vocals on 264 in buffer size, 24 bit, 48KHz. 4 processors, 90% Usage and level 4 in playback buffer. Surely everything should work without any problems? Need help! http://img410.imageshack.us/img410/9803/erroryc.jpg |
Re: Why do I get this "error" ALL THE TIME?
Sandra report please.
Read the General troubleshooting thread. We need more info about your system. |
Found this at least...exactly how crucial is this? I have all sounds on the same drive as my OS at the moment.
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive. |
Very important. Pro Tools is not supported with only 1 drive. Partitioning a single drive is no good either, you need to be using a dedicated audio drive.
Internal drives are the best, with the 'WD Caviar Black' a solid choice at the moment. If you need to buy an external, use firewire with a supported chipset, which you will find a list of in the support pages. DO NOT use USB external HDDs, these are not supported. It may not be your only problem however, so post a Sandra report. |
Yes, generally when the word MUST is used, it's rather crucial.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
LOL! i would have to agree, nay nay I say, nay nay!! I MUST agree with that statement.
I "MUST" also agree, thought even though I did all the "Must's" and (I think) them some, I still get some errors (seems to be mostly in front of clients.....I swear I can work on my tunes for days without errors and then I get a client in the studio.......:confus ed: sometimes it works well and sometimes not so well)...I have been running Pro Tools since the very first 001's, 4 different custom built (and some WAY too expensive) pc's and ALL have had issues.
You have to follow ALL of the "rules" and this might not yet give you error free results, but you can make music....think of how it used to be with tape:rolle yes::rolle yes::rolle yes::rolle yes::rolle yes::rolle yes: I think even with all the errors its still rock to be able to play in this world yeah my faces show I had a few |
You have to follow ALL of the "rules" and this might not yet give you error free results, but you can make music....think of how it used to be with tape:rolle yes::rolle yes::rolle yes::rolle yes::rolle yes::rolle yes: I think even with all the errors its still rocks to be able to play in this world yeah my faces show I had a few |
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
MC Mix connects correctly first time, "Network Error" after power cycle. | A Chapman | Artist Series | 4 | 07-18-2011 03:04 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
Error 7053, "Wm exception". "TDM ProcessTypeGlues"(!) and SoundToys greyed out ! | LSNY | macOS | 1 | 02-08-2011 04:16 PM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
