#31
Re: Routing Automation - Why Isn't this Done?!
I give the PT programmers the benefit of the doubt in figuring that certain kind of basic things that are missing (especially the ability to have more than one timeline open at once) are still missing because it would be a major deal to change (fix) them. I guess that might be true of greater interop between Avid MC and PT (WITHOUT AAF etc) as well....
#32
I believe routing bussing on a digital console is more like muting every other bus. So not being able to, on the fly, change where a track is going is a DSP saving system. Let's say you have 1 track going to 60 different possible busses. You have to have the DSP for all 60 bussing on all the time to make that track be able to change bus assignments on the fly. If that same track is just going to 1 bus, you are saving 60x the DSP over the bus automation system. This might not be a big deal for a console with a huge chassis that can fit a huge amount of cards into but trying to fit enough chips onto a pcie card to do this is a challenge I'm sure avid can't do at this time.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
#33
I've never run into a situation where I've needed more than the 2 DX re-assigns when mixing virtual. |
#34
I'd still like to see POST Inserts in PT. I think it could easily be implemented as a switch for the second bank of inserts. I rarely use that bank, but it would be nice to have the option for post fader there. In addition to the features mentioned above. |
#35
I admit I haven't read thru the whole thread, and I'm shure most of you pros know this: output assignment of tracks can be multiple. Cntrl-click (mac) to add output assignment. I think many, like me for many years, are not aware of this.
My point is: you could always route stuff multiple places, then use mute automation. A workaround, of course. Just my two cents. |
#36
Haven't really thought in terms of any particular paradigm in quite some time. Really, I'm a guy who understands signal flow and wants to find the best possible way to finish my mix and keep my clients happy. I use two reassigns in much the same way that you do. My third reassign is a FUTZ reassign.... and the fourth is a utility player ... sometimes it's an additional futz bus (for A/B Futs splits) and sometimes it for reassigning foreign languages (to keep our M&E people happy) and sometimes it for odd jobs like panning processed dialog differently. My goal is to be as flexible and as efficient as possible. I'm able to do everything I want to within ProTools right now ... all via workarounds. I just would like to see Avid take the needs of the post community seriously and implement features the pro market needs so we don't need workarounds to accomplish these goals. BTW Mark ... you still owe me lunch! Peace, |
#37
#38
My work around is to duplicate my sends. One being POST and the other PRE. I then mute between them. It's a pain, but it works. Same with routing automation. And I hate having to use up valuable sends to do what the console should already do. Anyway... hope all is well with you Peter. Devastated about Ed Greene. Best always, |
#39
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12 |
#40
I may be old school in saying that I too miss automated routing in PT. DFCs have it, my System5s have it, and yes, Nuendo also had it (called direct routing, where you have 8 slots that can be filled with destination groups, busses, or FX, and then automated).
For the moment I use sends, for lack of a more elegant solution, but as I usually have a minimum of 4 (sometimes up to 6 or 8) reassign Busses for Dx, it can get a bit cramped... So here is hoping that PT gets that eventually. Sent from my Galaxy S7 |
difference between MIDI automation and Audio automation on Instrument Track? | mariam | Getting Started | 5 | 04-28-2016 03:55 PM |
Can't turn off capture automation on the automation panel | tandem | Post - Surround - Video | 0 | 07-16-2014 09:36 PM |
Routing out Logic 1 & 3, anyone know basic Logic routing? | soundonsound | Pro Tools TDM Systems (Mac) | 2 | 06-04-2008 10:42 PM |
Routing in automation | mik | Pro Tools TDM Systems (Mac) | 3 | 11-19-2007 05:52 PM |
Automation Mixing - Bus Routing (very technical stuff) | TheNoize | General Discussion | 17 | 07-05-2007 11:22 AM |
