Old 06-23-2009, 09:29 PM
maxxer maxxer is offline
Default Can MIDI control plugins at ALL????
k - hope this is a stupid question. Is there any way AT ALL to use a generic MIDI controller to control the parameters on an audio RTAS plugin. (i.e. not a virtual instrument plug)
please help!
Old 06-24-2009, 05:28 AM
johnbhoy johnbhoy is offline
Default Re: Can MIDI control plugins at ALL????
Yes . See the post a few down below about nanoKontrol.
I have used the same settings to plug in my original Evoltion X-session controllor and it controls the mixer and 8 knobs of any rtas plugin.
What I had not realised was there is a learn functionality with the rtas plugins. This learn funcitionality switch only shows up when you have set up a midi controllor properly in the midi settings tab… IE either using the cs10 profile or using the m-audio keyboard profile. ( what I am not 100% sure of is if this m-aduio profile will work with just any controllor. It may, It may not. The evolution x-session was bought over by M-aduio and they now provide drivers for it so unsure if this makes it work when others may not).
Hope that helps
Old 06-24-2009, 09:11 PM
donmr123 donmr123 is offline
Any chance you could give a more detailed description of how to set this up? I have been struggling for days to get my expression pedal in my Axiom 61 to control the AIR Fuz Wha plugin so I can use it as a normal real time wha pedal. tearing my hair out!!!
Cheers
Don
Old 06-25-2009, 12:12 PM
Not that would contain any more information thats already in the post i pointed out. i would just be repeating whats already there.
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 02:36 AM
Midi control for plugins? Blackdawg MIDI 4 06-07-2011 05:20 PM
Control surface lag when in plugins view/control crizdee Pro Tools TDM Systems (Mac) 6 12-17-2010 04:01 AM
getting midi controler to control plugins paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-07-2007 06:04 PM
midi control of plugins jum MIDI 0 10-06-2003 04:50 AM
