Old 11-04-2016, 06:01 AM
SnakeyD2 SnakeyD2 is offline
Default No such file or directory (2) while creating "Plug-In Settings".
Hi Guys,
Recently I've started getting this error 'Could not complete your request because No such file or directory (2) while creating "Plug-In Settings". '
No idea where it has come from.
It happens at the loading screen after 'Midi engine initialisation', it flashes something about controllers then the error pops.
Any ideas?
EDIT : Here are my system details
27" iMac Late 2013 OSX 10.10.5 3.2ghz core i5 8GB DDR3 1TB HDD
Pro Tools 11.3.1
Focusrite Scarlett 2i2
Behringer Truth B3031A Monitors
Old 11-04-2016, 06:07 PM
Default Re: No such file or directory (2) while creating "Plug-In Settings".
Your iMac - does that have a Fusion system drive? Those have been known to cause all kinds of problems with PT.
Jack
QAPLA!
Old 11-08-2016, 06:38 AM
It doesn't. It's just a standard 1TB hard drive
Pro Tools 11.3.1
Old 11-08-2016, 11:12 AM
Thanks for that info. Did you install PT wherever it wanted to be installed? Are you running as admin? You really should be doing so. Could also be a permissions problem. Repair permissions, delete prefs & databases (use Pete Gates's utility) and try again.
Jack
QAPLA!
Beat Detective: Region Conform "Strength" "Exclude Within" Settings ? sleepwalk Tips & Tricks 1 03-04-2016 11:37 AM
[Bug: PTHD10] Plug-in settings paste error "Not Compatible" jeremiahmoore Post - Surround - Video 4 02-22-2012 10:29 AM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
"Plug-in Inactive" (plug-in settings lost after upgrade from 7 to 8) Thyrium 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-25-2010 07:31 PM
Launching PT Free: Stuck on "Creating Plug In Array" Dweizmann Digidesign Hardware & Software 2 02-21-2003 05:07 PM
