Old 05-10-2011, 02:28 PM
WildHoney WildHoney is offline
Default Splitting a session's audio files over multiple drives
Can anyone direct me to a tutorial on how to split a session's audio files up between more than one hard drive? I've gotten in a massive session here that they want to do some edits to, but just trying to run everything off of the internal SATA drive is throwing disk errors left and right. Won't play for more than a couple beats at a time. Hoping if I split up the audio files across two drives it'll run.
PT9, OS 10.6, 16GB RAM, Intel 8-core Xeon 3.0GHz
Old 05-10-2011, 02:32 PM
Craig F Craig F is offline
Default Re: Splitting a session's audio files over multiple drives
put another internal drive in
make a session folder then an audio folder inside on the second drive
copy half of the audio files to the new folder
delete what you copied from the original drive
launch Pro Tools
make sure the new drive is set to Record in the Workspace
open the session
relink to the new location
Thank you,
Craig
DarylG DarylG is offline
Just move half the files over to the 2nd drive, and then re-link them. Very quick and easy. I'm running off 3 drives for the current mix, and recording stems to a 4th drive...!
D
ProTools 9.02
2 x Intel Xeon x5675 3.07GHz Hex Core
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
ATI HD5400 series graphics card
Old 05-10-2011, 03:02 PM
Brilliant. Thanks guys. Can't believe how simple that was. Just have to remember to bring everything back together before backing up!
Old 05-10-2011, 03:06 PM
Bill Denton Bill Denton is offline
Maybe these other guys know you personally, but since I don't I'll ask the obvious question...
... the internal SATA drive ...
That's not your only internal drive, is it?
Given you're computer's specs I would tend to guess not, but you never know...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-10-2011, 03:09 PM
Greg Malcangi Greg Malcangi is offline
Default
You don't even have to remember to do that. Just use the "Save Copy in ..." command. This function will gather your files automatically from whatever drive they are on and back everything up to a single folder wherever you specify!
G
Old 05-10-2011, 03:19 PM
No, no, I've got 4 (I think). Lack of drives is not the problem
Just wasn't sure how PT would go about finding what it needed.
Audio files on multiple drives Steve White Post - Surround - Video 2 03-03-2011 01:22 PM
Splitting audio tracks between two drives? Gene100 General Discussion 7 02-11-2011 12:23 PM
Splitting audio tracks between two drives? Gene100 Storage Subsystems 2 02-10-2011 02:57 PM
Why doesn't PT look for files in the session's Audio folder first? trombino Pro Tools TDM Systems (Mac) 4 09-14-2001 09:22 AM
Deleting unused regions, but the audio files still are in the session's folder....... Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-09-2001 07:11 AM
