Old 12-26-2010, 05:29 AM
Aaron Troughton Aaron Troughton is offline
Default Drive Partition
My pro tools PC is currently offline and has never been connected to the internet for performance and clutter reasons (updates ect are downloaded from a differfent computer)
Im thinking of connecting it to the net to quicken the update process and to possiblly install a few games as i miss being able to play my PC baised computer games but I never intended to conect it to the net and i would really like to keep it that way.
however would creating a partition on the OS drive and installing the net + games ect on that side make a difference?
Cheers.
MUSICIAN & MUSIC PRODUCER
WWW.STUDIO-STUDIO.CO.UK
UK RECORDING STUDIOS
WWW.ATTIC-MUSIC.CO.UK
MUSIC PRODUCTION COMPANY
Old 12-26-2010, 05:38 AM
Dism Dism is offline
Default Re: Drive Partition
Your best bet would be to install a separate physical hard drive and boot from that for gaming.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-26-2010, 05:42 AM
Would i have to load the boot menu each time i wanted to switch from game to pro tools drive?
Old 12-26-2010, 05:43 AM
TCM's Avatar
TCM TCM is offline
My PT rig has two hardware profiles, one for just music production, network disabled, the other network enabled to download music production related files.
I try to keep my rig as clean as possible.
I would be careful to install games, as
1. some of the copy protection is down at the system level which may cause conflicts with PT
2. some of the game files may also alter some system files, which again may cause trouble
Just some food for thought, I personally have no experience installing games on my PT computer!
my2c
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 12-26-2010, 05:44 AM
TCM's Avatar
TCM TCM is offline
Good idea!
Old 12-26-2010, 05:16 PM
Hotcrazyfruit Hotcrazyfruit is offline
i do a tonne of gaming on my rig. mind you iv'e got many hdd's one of which i use as a gaming and general use partition. gaming on 3 monitors is amazing
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 12-26-2010, 11:25 PM
Aaron, be careful when updating that you do not run into required system specifications that render Windows Hardware Profiles unsupported.
Aaron Mulqueen - 001 HD Native
Old 12-27-2010, 05:35 AM
Emcha_audio's Avatar
Doing a dual boot will be best for you. YOu can either do it on the same HDD, or one two different HDD. Yes you will always see the boot selection screen after the bios loaded. But this way, you can have two completely independent system working. One that is configured for PT and the vst's and other gear you are using to record. One for your normal use. ON the normal use you can have access to the internet and have your AV installed on that one, while on the PT boot, you can forgo the installation of the AV, disable the network card etc etc etc.
I myself do a lot of gaming, when I'm not working, and this is the best way to actually and efficiently set up your computer to do both, if you only have one computer. Due to it being two OS, you will be able to configure them independently for the hardware you are using. Ie video cards, sound cards, network cards.. etc etc etc.
Old 12-30-2010, 08:02 AM
Sounds great so far!
So, to recap:
1 HD for recording
1 HD for A/V stuff and the net
I just plug em both in and just boot from one or the other as and when required?
I also have a HD that i read/write to and from when recording, Can i leave this HD on in either case?
Drive Partition GEM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-30-2009 06:18 PM
Different partition or different drive necessary? Simmer Pro Tools TDM Systems (Mac) 6 11-18-2009 01:48 PM
want to partition my drive. best way to do this? wreckthisplace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-29-2005 01:28 PM
partition drive? Uelogy Storage Subsystems 6 10-08-2005 04:33 PM
how to partition drive? r0cker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-11-2001 12:41 AM
