Old 11-05-2010, 10:15 AM
mhelm01 mhelm01 is offline
Default PT 9 and Multiple Interfaces
I've been reading the new reference guide and I see that in HD you need to restart your PT system after changing interfaces. My question:
In a non HD system can I switch between different interfaces being active inputs without having to change the output?
For example: I have an 11 rack and a 2626. I'm tracking guitar through the 11r and monitoring without headphones. I then want to record a small kit and use my 2626. I will need to use cans because I don't have a separate tracking room, but my signal out of pro tools is 11r>headphone amp>monitors. If I switch to the 2626 as my primary I/O can I still leave the output through the 11r?
2.66GHz Quad-Core Intel Xeon
6 GB SDRAM
3 1 TB WD Caviar Black Hard Drives
Eleven Rack, Axiom 61
Old 11-05-2010, 10:30 AM
Default Re: PT 9 and Multiple Interfaces
You can use Core Audio aggregate if all your device drivers support it. Avid's drivers for their hardware do no support aggregate device.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-05-2010, 10:36 AM
I saw that. I guess my question is can I change that on the fly?
6 GB SDRAM
Old 11-05-2010, 03:13 PM
finkbmx finkbmx is offline
Hey, you have no idea the power us 11R/profire2626 users have. I bought the profire before the 11R came out and then got the 11 rack for "latency free" tracking of guitars. Which as we all know, does not exist on the 11R out of the box. So i started thinking. My profire has a zero latency(or damn close) dsp mixer. Why not patch the 11R outputs s/pdif or analog into the profire and enjoy latency free monitoring while still using the profire inputs.
So, basically to get the best of both...
Use your profire as the main interface.
Patch the 11R into it, I prefer s/pdif because you can keep your analog inputs free. The box will allow you to choose a wet/dry combo of 2 signals via s/pdif or a wet stereo.
Then plug in your 11R via usb which will allow you to track with embedded settings and control the unit from the PT window.
Done!
If you have any questions about the setup feel free to PM me.
Good Luck
Old 11-06-2010, 10:31 AM
de_flon de_flon is offline
Hi.
So I cant use my headphones on the 11R + the headphones output on my mac pro?
The thing is that I would like to be able to record a small band live, but that is impossible.
I hoped that I could use the headphones on mac Pro + 11R headphones and then Profire2626 Headphones. If I could then I would have 4 headphone outputs.
Thx
Remi
Old 11-06-2010, 10:49 AM
formfunction formfunction is offline
Thx
Remi
If you don't need 4 discreet HP mixes, just buy a headphone amp.. many are under a 100.00 and have 4-8 headphone outs.. ff
Old 11-06-2010, 10:58 AM
Can you mention any good ones?
And are those connected through 11R or USB?
Old 11-06-2010, 11:22 AM
nst7 nst7 is offline
Here's a bunch to check out, at all different prices and features:
http://www.sweetwater.com/c413--Head...d_Distribution
If you tell us more specifically what you want to do, maybe we could offer specific suggestions.
Old 11-06-2010, 11:54 AM
Thank you so much!
Now that Pro Tools 9 has been realesed I dont really need to put my money in an HD system:
So.. I would like to have like 8 Inputs/outputs + 11R and 4-8 headphone outputs.
I am using Steven Slate Drums and R td9kx for the drums.
I need 4 inputs for acguitars, 1 for bass, 2 for vocals + 11R for elguitars.
Remi
Old 11-07-2010, 03:03 PM
Hi.
Thx
Remi
The profire has 2 headphone outs that you can assign so you have 2 separate mixes. then you can assign a third mix to any 2 outputs and patch them into a headphone amp. this will give you 3 separate mixes, one with as many outputs as the headphone amp has. You can also do more mixes if you get a headphone amp that has more than one input that you can assign to whichever headphone out you want. The profire is a pretty sweet device, read your manual.
[IMG] code is Off
Multiple interfaces in pt9 HD? muddboy macOS 7 05-12-2013 11:23 AM
Multiple interfaces Julia B Pro Tools M-Powered (Win) 3 06-22-2011 08:07 PM
Multiple interfaces to PT9 towelhead macOS 3 05-26-2011 10:18 AM
Multiple Interfaces? grimepoch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2008 06:30 AM
AES/EBU on multiple 96 interfaces Robin Reumers Pro Tools TDM Systems (Mac) 0 10-12-2006 09:41 AM
