Old 11-02-2009, 10:25 AM
5Grand 5Grand is offline
Default not able to drag anything over to my other monitor when dual screen
When i open pro tools it runs in vista basic compatibility mode as far as the display, and then my display gets caught off, also i am not able to drag anything over to my other monitor when dual screen
Old 11-02-2009, 11:11 AM
getz76 getz76 is offline
Default Re: Someone answer this really quick
Where's the question?
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 11-02-2009, 11:42 AM
How can i fix the screen issue it seems to cut off the whole right side of pro tools?
Old 11-03-2009, 05:56 PM
Driven01 Driven01 is offline
Default Re: not able to drag anything over to my other monitor when dual screen
Click the Maximize Down button in the upper right corner of the screen (you know, the square next to the X). Then put your cursor over the right side edge of the PT window. Your cursor should change to a double-ended arrow. Drag the edge of the PT window (resizing it) to the edge of your other monitor so that the PT window covers both screens. Now you should be able to move things around in PT between both screens.
Dual monitor vs single monitor setup Whasssaaahhh Pro Tools 9 23 03-17-2014 01:24 PM
Monitor screen is jerky GuyPicks Pro Tools TDM Systems (Win) 11 09-03-2010 01:45 PM
monitor screen and cpu redchair General Discussion 3 11-17-2009 02:09 PM
7.2 can't drag or select beyond screen right crizdee Pro Tools TDM Systems (Mac) 1 08-04-2006 03:47 PM
Dual Monitor / hardware playback with NTSC monitor TheBriceShow Post - Surround - Video 2 02-21-2005 05:58 PM
