  #7001
Old 03-27-2022, 01:22 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Free Windows 10 Audio Workstation Build and Tweak Guide
Originally Posted by EGS View Post
Just google "12th gen audio PC build" and YouTube search "12th gen audio PC build". Not that hard.
I did, thank you.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
  #7002
Old 04-20-2022, 10:09 AM
ValkRider ValkRider is offline
Default Re: i7 Builds - Specs and Results
Hello,
I am considering a new computer build. My system is very old at this point.
I want to start with finding if Thunderbolt 3 should be a desired part of the build.
I haven't seen TB3 mentioned with folks that are building with the new
Intel i9-12900k cpu's and DDR5 memory.
Should it be a high priority when considering a new build?
I have built many systems myself in the past but it has been a while.
Also I am considering purchasing a new interface so thought maybe TB3 would be the way to go.
I am a hobbyist so don't have a business studio or anything like that.
My other concern is about getting a new maybe 32" or so monitor.
I have two old 24" DVI type connector monitors and I thought I would upgrade that.
My old tired eyes aren't what they used to be. Any suggestions regarding monitors now a days.
I would appreciate your thoughts on it.
Edit: I did find this with a very fast search, I didn't know TB4 was even out there. This example has a header on MB but not inline connector built in.
https://www.asus.com/us/Motherboards...690-PLUS-WIFI/
This will be DAW only no games.
Edit2: I looked at this motherboard also which has header connection on the MB for TB4
so I will guess having Thunder Bolt will require a addon card.
This Gigabyte board also has MB header pins for TB4
https://www.gigabyte.com/Motherboard...STER-rev-1x#kf
This MB also only has two PCIE4 expansion slots and one gets disabled if you use all the M.2 connectors on the MB.
I'll keep researching.
Thanks for any guidance.
"So it goes", Kilgore Trout
  #7003
Old 04-22-2022, 06:45 PM
EGS's Avatar
EGS EGS is offline
Here's a 12th gen MB with Thunderbolt4: https://www.newegg.com/p/N82E1681314...quicklink=true
and a Thunderbolt 3 audio interface: https://www.presonus.com/products/quantum-2626
Click for audio/video demo
Click for resume
  #7004
Old 04-24-2022, 03:35 PM
Thank you very much. I had not seen that Gigabyte MB.
I was wondering if air cooling like a Noctua unit is sufficient with the 125watt CPU's.
I would prefer air cooling over water. I guess I have a inherent mistrust of having liquid inside a computer.
I like the Fractal Design cases and have looked at the Define 7XL and their Meshify 2.
Lots of internal fan possibilities for a good push pull air flow setup. A lot more to research yet.
  #7005
Old 04-24-2022, 03:40 PM
Skwaidu Skwaidu is offline
I'm doing acceptably with a Noctua NH-D15 in a Define R6 with the basic 2 in 1 out confg (front usually open).
Even have a 300MHz all core OC going with some undervolting on the i9 - it can thermal throttle slightly on synthetic loads (like Prime95) but extremely rarely in PT use. The only example would be a long all-core demanding offline bounce, but it's not a significant issue, the one-core boost I get from x52 all P-cores in PT is more than worth it.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #7006
Old 04-25-2022, 01:03 AM
zedhed's Avatar
zedhed zedhed is offline
Originally Posted by zedhed View Post
Hi @EGS
I'm in the process of looking at a new build and yours looks similar to what I'm thinking about.
So far I've narrowed it down to the following;
Motherboard: Gigabyte Z690 AERO D
CPU: Intel i9 12900K
RAM: (Haven't decided on Brand ) 64gb DDR5
UPDATE:
I've finished my new build (Dedicated Pro Tools only Rig...Running PT11HD v 11.3.2).
Motherboard: Gigabyte Z690 AERO D.
CPU: Intel Alder Lake Core i9-12900K 16 Core/24 Thread.
CPU Cooler: Noctua NH-D15S (with two fans, push/pull) Extra Fan.
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) 2 slots free.
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples).
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (System Win 11).
PSU: Corsair HX Series HX850 Platinim (Modular).
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4.
CASE: Fractal Define XL R2, Extra Fans.
I have only done a test run with Pro Tools so far, but wow this thing kicks ass!
I can't speak highly enough about the Fractal Computer Case, running 5 fans (7 mounts) and is extremely quiet. Solidly built and shields EMI very well too.
Too much blood in my drugstream
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
  #7007
Old 04-25-2022, 03:35 AM
UPDATE:
I cannot say enough about the Fractal computer case, running 5 fans (7 mounts) and is extremely quiet. Solidly built and contains EMI very well too.
Congrats! Nearly identical system to mine, except I built my system with DDR4 due to launch availability. Curious though why you are not on PT 2021.12?
  #7008
Old 04-25-2022, 04:37 AM
zedhed's Avatar
I couldn't bring myself to go the subscription route and 11 does everything I need. It's been incredibly stable and is as much so on Win11.
One day I might move up but the money I've saved by sticking with what I've got, has gone part way to enabling this build.
Edit: Thinking about it, it's probably completely paid for it.
HD 96I/O
  #7009
Old 04-25-2022, 05:04 AM
Ok. The software has moved forward massively since though (and also native performance on low buffers seems to have improved massively just between 2020.3 and 2021.12!).
FWIW I'm still with a perpetual license and pay the upgrade tax. Reinstatement is still possible I think, at least through 3rd parties (to keep the perpetual and get back to the upgrades).
  #7010
Old 04-25-2022, 07:08 AM
EGS's Avatar
EGS EGS is offline
I'm using a Zalman air cooler with two 120mm push/pull fans. Plus case intake and exhaust fans. Noctura lowest db/lowest rpm fans for all. I'm using a 4RU case, and it's almost inaudible.
Click for resume
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
