modern tone modules seem to be stuck in the dark ages.
There's quite a few tone modules from novation and access inparticular that sound fantasic to me.
The all use phsysical modelling and admittedly an SP/DIF / ADAT board is available for some of the Novation products. It just seems stupid to make products that are 100% digital but sound like very clean analogue (in the synthesis sense), then don't even have any digitial I/O. I'd love a virus rack if it had SD/DIF and ADAT. It sounds great, I could leave my analogue inputs free to play my mac through while hooking up the synth through the SD/DIF. later on I could get a Digi001 and then actually process AUX sends through the unit. Except I can't and I never will be able to because even when I do get a Digi001, I'll be limited to Korg and Novation stuff if I want to keep everything digital. The Digi001 does have those extra inputs though. Is anyone using any of the Access or Novation synths with protools as both a synth and filter effect ? It seems to me that even after a few years, the Korg OASYS still looks like my best option as a future add on to my setup. Plenty of things sound as good, even sound better but for the most part they just don't have specs & I/O options to match. |
Re: modern tone modules seem to be stuck in the dark ages.
haha, as if he can find one.
just saw one on the OASYS group, they are out there...
they are always on ebay - generally go for about $400. You can not beat that deal for the quality of the Oasys. They are awesome!
I was kind of thinking the OASYS is not just my only option but the best one too.
I've tried the OASYS editor, it seems like I'd need to create a new oasys mixer setup for each tune I'd make with it in protools. How easy is it to integrate with protools ? Can you just have the combined stereo output from the OASYS going through the SP/DIF on an AMIII card and then just choose the patches you want on each midi channel from within protools. Basically making it behave like a multitimbral tone module with all the patchnames in an OMS document ? It also seems from playing with the OASYS editor, you can only have 12 mixer channels, doesn't that mean I'd only be able to route 12 synth outputs through the SP/DIF ? I'd be looking at running the audio output from the synth tracks on the OASYS card into the SP/DIF on the AM III. For Fx returns I'd want to be running the SP/DIF output of the AM III to the SP/DIF input on the OASYS, returning the signal back to Protools through the main analogue outputs on the OASYS into the analogue inputs on my AM III card. That way, I could still monitor through my AMIII outputs like I do now. I could definately get one for my birthday (around mid august ) if I could save enough by them to put towards it. |
I can't fully answer your question cuz I'm not a big synth/midi guy, but I will tell you if you want to use the Oasys priamrily as a synth you might be disappointed, because the synth patches take up a large amount of DSP, so you might only be able to run 3 to 5 synth patches at one time before all the cards memory is maxxed. If you use it only for effects you won;t have this problem, however.
Sessions take ages to load up? | Moviesound | Post - Surround - Video | 0 | 03-23-2011 02:52 AM |
Test Tone Audio File or Tone Generator | Imagine | Pro Tools TDM Systems (Mac) | 4 | 04-15-2005 06:28 AM |
What kHz Tone to Generate for Tone generator | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-30-2004 07:50 AM |
Looking for a shortcut I THOUGHT I saw ages ago | medievil | Tips & Tricks | 3 | 02-27-2004 05:19 AM |
Audio 2004: Dark Ages or Age of Enlightenment? | RobMacki | Pro Tools TDM Systems (Mac) | 11 | 12-11-2003 09:56 AM |
