  #61
Old 12-05-2020, 11:07 AM
Default Re: Only hearing music out of the left headphones
Originally Posted by Rstar View Post
Hi I am also having this problem but have followed these instructions. I have a feeling it is something to do with my audio interface or settings on pro tools? I am only hearing through left head phones, even a stereo track i imported.
I am using audio kontrol 1. Could it be that my cable for connecting to my computer is for a printer and not strictly audio cable? Otherwise my cable for my mic came with it. It is rode.
Thanks for any help.
Assuming you are using a USB cable, any USB cable should be fine(its carrying data, not analog audio). Its more likely either a software setup problem(the software that comes with Kontrol 1) or a connection mistake. Some folks get confused on TRS jacks. These jacks are used for headphones, AND for balanced inputs/outputs. With a headphone jack its a stereo signal but for a line input/output, its mono and balanced.
  #62
Old 12-13-2020, 06:55 AM
Rstar Rstar is offline
Thanks so much for this. Ok so the TRS jack business - i just looked up what this means and looks like need TRRRS for balanced stereo output. The headphones lead have 1/8inch pin so i'm using a converter to 3/4inch for the audio kontrol interface. The jack converter has 3 bands on it. I think that means it's TRRRS. Is this right? Is this what I need?
If it's to do with the software for the audio kontrol 1, any advice on how to access or cofigure that is much appreciated.
Computer model and processor speed: Zbook Intel(R) Core(TM) i7-6700HQ CPU @ 2.6 GHZ 2.59 GHZ
OS version: windows 10 version 1909 64 bit
Avid hardware model: audio kontrol 1
Pro Tools version: Pro tools first
Amount of Memory installed: 32GB
  #63
Old 12-13-2020, 08:24 AM
To the best of my knowledge, the mini TRRS is only found on tablets and phones. I know of no interface that uses that connection. Back to TRS: for headphones, it acts as stereo, with left on the T(tip), right on the R(ring) and sleeve is the - side of both signals. With balanced inputs and outputs, the Tip is signal +. the Ring is signal - and the Sleeve is ground/shield. Look at your mini>quarter inch adapter as maybe it only has Tip and Sleeve(in which case, its just the wrong adapter). It should look like this:
https://www.amazon.com/NANYI-Female-...xpY2s9dHJ1ZQ==
hearing vocals in headphones mgsr70 macOS 16 12-09-2012 11:16 PM
Hearing vocals in headphones as i am recording it. abikambic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-19-2012 07:11 AM
Hearing sound through headphones, but no visible signal in PT 8 LE Alexthepirateguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2010 05:44 PM
Hearing pops in headphones macbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-23-2010 12:10 AM
keeping recording levels, but not hearing through headphones badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-02-2002 10:31 AM
