Re: Pro Tools 11 corrupt file
The new installer is there! I am downloading it now. I will report back after I have installed it. Hopefully everything will work with iLok. It is not showing up in iLok. Maybe after I install it?
The iLok authorization has nothing to do with the installation. If there is no licence on the iLok, you won't be able to run successfully installed PT11. They are two separate issues.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Still not working!!!
I got it to download but now it won't run because iLok will not authorize! I know this is off topic on this post so I will post another topic.
Deleted old download (79511.dmg) and cleared cache. Went back to My products and downloaded PT11 installer again, this time it was 79652.dmg. Installed perfectly. This solved my issue. Hope this helps someone else.
Digi OO3 PreSonus Digimax D8 Pro Tools 10.3.6/11 MacBook Pro 9,1 2.3GHz i7 Quad 16 GB Ram OSX 10.8.4 External Glyph Drive 500 GB, Firewire 800, 7200 rpm JBL LSR4326 monitors 24" BenQ External HDMI Display |
#16
If you have then the next step is to sort the iLok problem out.
#17
Yes it installed ok. I am not sure what to do now with iLok. On Avid's website it says to go to iLok to retrieve my license but it is not there. It still says Pro Tools 10.
#18
You might want to look at the iLok problems threads (there are plenty of them). There seems to be some issues relating to ilok licence transfers.
#19
Best Chris
#20
I was eligible for a free upgrade after I purchased PT10 box. Thanks
Corrupt Pro Tools 8 ZIP File | jason13ie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 44 | 10-16-2015 04:37 PM |
Pro Tools Updates 8.0.5 corrupt file link | Pro3000tools | Pro Tools M-Powered (Win) | 1 | 02-07-2013 05:45 AM |
Corrupt PT8 LE Zip File | Enerjex | General Discussion | 7 | 01-04-2010 10:04 AM |
possible Bad HD or Corrupt file, any help what to do ? | stereoaction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-11-2009 06:37 PM |
Corrupt file??? | Sounds Suite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-18-2006 05:32 AM |
