Old 03-07-2011, 12:02 AM
Becure Becure is offline
Default Turntable => DJ Mixer => Mbox 3?
Hello!
Is it possible to have this setup: Turntable => DJ Mixer => Mbox 3?
I want to record vinyls and will I be able to record in stereo, and what cables do I need?
It's a Ecler Nuo 2.0 mixer, with this inputs/outputs:
Thanks!
EDIT:
Searched around a little more, and this should work?
Turntable => Dj Mixer => RCA to 1/4" cable => Mbox 3
Old 03-07-2011, 08:27 AM
Default Re: Turntable => DJ Mixer => Mbox 3?
RCA to quarter inch should work fine. XLR to TRS may also work fine. XLR to XLR into the mic inputs MIGHT work fine as well. In any case, with the right cables, it will work fine.
Old 03-07-2011, 11:48 AM
Great!
I ordered 1/4" stereo TRS to 2x RCA, and that would fit in the XLR/1/4"-combo jack on the mbox, am I correct?
thanks!
Old 03-07-2011, 04:32 PM
Wrong cable. You need something like this: http://www.hosatech.com/product/3398...ual_RCA%2C_1_m
Old 03-07-2011, 07:33 PM
Craig F Craig F is offline
if the photo is your mixer then 2 like these XLR female to 1/4" TRS:
http://www.markertek.com/Cables/Audi...html?SC100XJSZ
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 03-07-2011, 10:03 PM
Thanks for the heads up!
So there's no way i can take a 2x RCA => XLR (y-cable)?
Old 03-08-2011, 07:31 AM
plastikman plastikman is offline
No, you should stick with Craig's suggestion. That is a better connection as the XLR(F) to 1/4" TRS maintains independent balanced connections for L and R... better than using an RCA unbalanced cable. If you use a Y cable, you would not be able to record in stereo as you would like to do.
Originally Posted by Dizzi45Z View Post
Pro Tools doesn't ever not cease to not amaze me.
Old 03-08-2011, 07:33 AM
No. Because the inputs of the Mbox are MONO and using a "Y" cable would be trying to stuff a stereo unbalanced signal, into a mono balanced input. It just doesn't work that way. Straight cables, one for left, and one for right are what you need.
Old 03-08-2011, 09:39 AM
Off course not, thanks!
turntable > mbox 3 > macbook mjhann83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-19-2013 10:50 AM
Turntable to Mbox 2 pro Ernie Reed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-03-2010 05:12 PM
Turntable mixer problem with Mbox n3xus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-15-2008 06:11 PM
Need help with connecting a turntable to the mbox 2!!! Help! dmt2828 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-15-2007 06:13 PM
Recording Audio from Turntable/Mixer!!! .tel Pro Tools TDM Systems (Mac) 4 12-08-2005 08:44 AM
