Playback and/or Record Continues 10-15 Seconds After I Press Stop With Spacebar. Lag.
Hey all,
Hoping someone can help with this issue. Pro Tools 10 becomes painfully slow when I'm working with it. Basically, when I hit spacebar to stop playback or recording, Pro Tools 10 will continue to play for up to 15 seconds after I've pressed stop. This comes and goes, and typically when I open a session, I won't have a problem until the session has been open for a few minutes. Interesting symptoms: - If I start playback at the beginning of the session and then stop it at the 10 second mark of my project, the playback will only continue for an additional 1 second or so. - If I start playback at the beginning of the session and let it play to the 3 minute mark of my session and stop it, then playback will continue for an additional 10 seconds or so. The more of my project I let play before I press stop, the longer the "runaway playback" is when I do finally press stop. - This same "lag" also applies to fader adjustments, clicking on or off the mute button on a track, and even simple scrolling. Everything lags exponentially worse the longer the file is allowed to play. I've been a Pro Tools user through versions 8 and 9 and never had this problem, so I'm stumped. Most of my sessions are virtual instruments. This is putting a huge road block in my work right now. Tried the CPU at 90%, 85%, 80%, and all had the same issues. Happens regardless of buffer size. Post-roll is not enabled. I usually have 10-20 instrument tracks in a session, but the CPU usage is usually below 40%. It's happened with the CPU usage as low as 25% before. This lag shows up pretty much every time I use Pro Tools. After just a few minutes the system will bog down. MacBook Pro 2010 2.4GHz Core i5 8GB 1067 MHz DDR3 RAM Lion 10.7.2 80 GB SSD (running OSX and PT), 500 GB HDD (recording drive) Pro Tools 10.0.1 Apogee Duet 2 Is this a problem with Lion? Is this an issue with PT10? I'm recording a live gig next weekend and need my system to be responsive. I can't imagine how long the lag would be if I recorded for 45 minutes straight... Thanks in advance! |
Re: Playback and/or Record Continues 10-15 Seconds After I Press Stop With Spacebar.
Got similar problems here - looks like a problem with Lion. Before I upgraded my OS from 10.6.8, PT10 ran smoothely.
Now with Lion it's a real pain.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
This is just a joke. The computer has revolutionized the recording industry right into the ground.
--- I am here: http://tapatalk.com/map.php?2amm50 |
Thanks for chiming in, Meads.
Wow. Hope there's an update that fixes this. If it's not resolved by next week I think I may reformat and start with a clean install of Snow Leopard. Lion's not so hot, although I do like it's syncing functionality with my iPhone/iPad...not anything that MobileMe didn't do though I suppose. Anyone else with similar issues? Anyone found a solution? Anyone figure out how to revolutionize the recording industry back into a functional computer? |
Looks like an issue with Lion. I rolled back to 10.6.8 and the issue seems to have resolved itself. What a mess.
This is exactly my experience and this has to be adressed by Avid asap.
10.1.2 officially supports OSX 10.7.3. Not for everybody though.
Can anyone verify if this issue is resolved with 10.1.3?
Also, does 10.1.3 still crash every time you change buffer size? |
10.1.3 made no significant changes on that subject for me.
Same problem here - I actually am running PT 10.2.0 with Snow Leopard!!
(I downgraded from 10.3.4 because my Artist unit had issues with touch sensitivity). |
http://www.pro-tools-expert.com/home...ntrollers.html .... and back to 10.3.4 |
How can I get the cursor to pause where I press spacebar instead of going back? | saltydeath | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-29-2011 08:05 AM |
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
"Press spacebar to stop playback..." | Osmin Camero | Pro Tools M-Powered (Mac) | 3 | 05-22-2009 12:26 PM |
"Press space bar to stop playback" ??? | EnzymeX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-04-2008 08:45 PM |
RTAS errors dont stop record/ playback anymore. | jimmyriserock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-04-2006 12:22 PM |
