Old 08-07-2001, 02:11 AM
sotagear sotagear is offline
Default Ideas for ducking music track?
My wife uses Pro Tools on a daily basis for voice-over work. She needs to have a music track duck down in level about a second before the voice over comes in & back up after the voice over is through. This happens numerous times throughout each production.
I figured a decent way to do it by cloning the vo & moving it ahead by 1 second, triggering a Drawmer ducker with the cloned VO track, while the Drawmer has been sent the music track to be ducked.
It's worked great for years & is much quicker than drawing the levels up & down on the music track.
However, we're trying to figure out an alternative to this setup that might be done strictly within the DAW, rather than having to send all of this out to the Drawmer & mixing the result through her analog board, as she's been doing at the moment.
Any ideas for an alternative way of doing this? Also - are there any ducker plug-ins that will do a similar thing?
Old 08-07-2001, 02:26 AM
Corey Shay Corey Shay is offline
Default Re: Ideas for ducking music track?
Put a compressor plugin with sidechain cabability (digi's work fine) on the music track, and have it respond to the early VO track thru bus sends. Pretty simple in PT actually.
Old 08-07-2001, 04:53 PM
snoopy snoopy is offline
How about buying the tdm (plugin) version of the drawmer?
Colin Miller
Teaboy Audio Recall Sheets
http://teaboyaudio.com
Old 08-08-2001, 01:30 AM
dstagl dstagl is offline
If I don't have time, I'll slap the compressor on the music track and sidechain it to the VO. If it's not kicking in fast enough, sometimes I'll duplicate the VO and nudge it forward on another track and sidechain the compressor to this.
But more often than not I find myself just doing manual volume rides if I've got the time because I always end up with the compressor pumping too much on the music.
Dave
David Stagl - Mixer | FOH Engineer
http://www.staglproductions.com
http://www.goingto11.com
french electro and pro tools track ideas tracy19 Pro Tools M-Powered (Mac) 0 08-07-2009 01:46 PM
Drum Track Ideas Kon Alexiou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-02-2007 02:54 PM
Drum track ideas and suggestions Kon Alexiou Tips & Tricks 4 04-30-2007 10:45 AM
Ducking Music Bed Under Vocals gai777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-22-2007 12:42 PM
Ideas for ducking music track? sotagear Tips & Tricks 5 03-31-2002 06:26 PM
