Breakpoint move line in edit window:How to disable
I accidentaly made a breakpoint line visible on a track. Every time I try to edit the waveform all I manage doing is putting a breakpoint move node on the track. I do not even want any automation on that track. In the mix window the same track has the tab above the pan readout set to off instead of read-touch-latch-write. How do I get rid of the automation or breakpoint feature for that track so I can edit the waveform under it? Thanks
Re: Breakpoint move line in edit window:How to disable
Alt click deletes the Breakpoint.
filosofem
Aaron Mulqueen - 001 HD Native |
...and, if you look in the edit window, be sure that that tracks track view is ticked on 'waveform' and not 'pan' or 'volume'. There aren't any automation options when veiwing waveforms.
Good Luck, Dave
Intel Core 2 Duo E6600/Asus P5W DH Deluxe/Nexus NX-5000/2 X 1GB CORSAIR PC2 6400/WD 80 & 250 GB Hard Drives/GeForce 7600GT/Lite-On CDRW/AcoustiCase 360/2-120mm AcoustiFans/XP Pro SP2/Mbox LE 7.3.1 |
also, set the option to 'read' in the mix window.
Peace
That did the trick thanks |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
Locked - Cannot use selection tool anywhere in edit window or move clips! | eneedham | macOS | 30 | 05-05-2012 08:23 PM |
Vertical line in Edit Window | Art4me | Windows | 1 | 07-02-2011 08:48 AM |
Hmmm, I cant move things about in my edit window. Any ideas? | AtomicLongie | Pro Tools 9 | 3 | 04-25-2011 12:27 PM |
Clicking in Edit window does not move playback marker...help! | Lofty11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-28-2009 09:01 PM |
