Old 12-18-2001, 12:13 AM
gammon gammon is offline
Default cant open session -> memory/translating tracks
could not complete the "open session ..." command because: there is not enough memory while translating tracks -> this is the error massage .....and the reason why PT 5.1.1 is not opening a PT 5.0.1 session.
also the session cant find some files but tey are in the right folder...and if i show him the files..it says "unknown type" ...i skip the files....and then the above error message is comming
all other old sessions i can open an work with without any problems.
does anybody have any idea about this error message
thanks gammon
Old 12-18-2001, 12:36 AM
d cham d cham is offline
Default Re: cant open session -> memory/translating tracks
We had a similar problem before. Try running Disk Warrior on the drive where the session file is located and then try rebuilding the desktop of the same drive.
Please let me know if this helps.
Dennis Cham
PT Editor / Sound Designer
http://www.sonicninja.com
Old 12-18-2001, 10:52 AM
jeffjuliano jeffjuliano is offline
I've been through your hell before!!!!! It started happening to me when I upgraded from my blue and white G3400 to my new Quicksilver 733 G4. I was getting the same errors that you are and random "memory is critically low please quit protools and allocate more memory" I would quit and the more memory I added the more it took! I called Digi bout this and they couldn't help and offered no solution....I got the standard "trash all your prefs, digi setup".......etc. After 2 days of troubleshooting I realized what was causing this was OSX sitting on a separate part of my hard drive. As soon as I wiped the drive and did a clean install of 9.2 everything worked fine....No more errors. Good luck! [img]images/icons/grin.gif[/img]
www.myspace.com/jeffjuliano
Can't complete the open session... because translating tracks DC-Choppah Pro Tools 10 45 08-09-2015 12:42 PM
Could not complete open session because error translating tracks spiritfallrecording Pro Tools 10 3 01-21-2014 08:31 PM
Could not complete the open recent session command because while translating tracks Peter Manganay Windows 3 12-04-2011 03:41 PM
Session will not Open (not enough memory) Geoff24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-23-2008 02:36 PM
