Old 05-08-2015, 01:54 AM
LanceK LanceK is offline
Default Not enough voices?
I just got the following message when opening a session I just recorded with 24 tracks....Any help?http://duc.avid.com/attachment.php?a...1&d=1431071633
File Type: png Screen Shot 2015-05-08 at 5.49.49 PM.png (26.7 KB, 0 views)
System Details: Macbook Pro 17"
OS 10.7.5
PT 10.0
8 gig ram
FW Drives (Multiple)
eSATA Drives (Multiple)
lance.crive@bigpond.com
Old 05-08-2015, 09:11 AM
Emcha_audio's Avatar
Default Re: Not enough voices?
that basically means that the session was done on a HD system and when you tried to open in natively, there's more playable track than native allows
session sample rate 48 / 96 / 192 kHz
playable tracks 96 / 48 / 24
Although since you recorded only 24 tracks.. that seems odd.
Manny.
Old 05-08-2015, 09:36 AM
What exact version of Pro Tools are we talking about here? LE, SE, Express, First.....
Old 05-08-2015, 04:09 PM
I have 10.0 HD pro tools. The session it came from was HD PT11. I've even tried a new session and importing the audio and it does the same thing. Even 1 track......
OS 10.7.5
PT 10.0
8 gig ram
Old 05-08-2015, 04:35 PM
Craig F Craig F is offline
RTAS after TDM, RTAS on Aux, and Hardware Inserts eat voices
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 05-08-2015, 04:47 PM
I have no plug ins or inserts....Just trying to play the raw audio.....
OS 10.7.5
PT 10.0
8 gig ram
Old 05-08-2015, 11:34 PM
JFreak's Avatar
JFreak JFreak is offline
So you import one track to a PT10HD session and it says you have ran out of voices? That doesn't seem right... Are you sure? Do you really mean you have a brand new empty session where you import one track and not enough voices?
Janne
Old 05-09-2015, 05:18 PM
That's exactly what happened. Even with 1 track of audio.....very strange and not sure how to get this to play.
OS 10.7.5
PT 10.0
8 gig ram
Old 05-09-2015, 05:47 PM
So does your system work OK if you create a new session? Create a track and play back in that session? New totally empty session, not from a session copy, not from a template. If so then try just importing one track of the audio content (just the audio content) into that new session ... that audio content should not break anything. Make sure you are trying Import Audio *not* Import Session Data.
If there are still problems then try all the usual troubleshooting steps... trashing prefs, removing all plugin files from their RTAS and AAX folders (yes even if you are not using any plugins), testing from a new clean admin account, checking firmware and drivers are up to date, running digitest...
Old 05-09-2015, 10:34 PM
Thanks Darryl, That's exactly what I did and still couldn't get it to play. New session and old sessions work fine. And seems to be only that audio from that session....
OS 10.7.5
PT 10.0
8 gig ram
DSP and Voices mwelles Pro Tools TDM Systems (Mac) 2 01-28-2010 10:09 PM
dsp and voices ? jackp Pro Tools TDM Systems (Win) 6 10-26-2009 12:29 AM
How many voices???? shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2006 08:54 AM
what to do when all 32 voices are used? time808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2005 10:33 AM
Voices,Voices,Voices..How to do it!? 002?MBox?HD? TheMadStudent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-07-2005 10:16 AM
