Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 09-30-2014, 02:44 PM
LanceK LanceK is offline
Default Eq to faders on S3L?
So is there a way yet to get the eq's to faders on the S3L's ? And if not.....WHY????
System Details: Macbook Pro 17"
OS 10.7.5
PT 10.0
8 gig ram
FW Drives (Multiple)
eSATA Drives (Multiple)
lance.crive@bigpond.com
Old 09-30-2014, 03:29 PM
TheMAXX TheMAXX is offline
Default Re: Eq to faders on S3l?
In Ver4.5 Yes! You assign it to a user defined key.
Old 10-01-2014, 04:28 AM
Very cool!! Thanks!! :)
OS 10.7.5
PT 10.0
8 gig ram
Old 10-03-2014, 06:26 PM
Default Re: Eq to faders on S3L?
Can someone tell me how to assign this to the user keys? TIA
OS 10.7.5
PT 10.0
8 gig ram
Old 10-03-2014, 07:27 PM
EQ on faders – under the options tab go to the events page.
Select NEW and then in the TRIGGERS window click ADD and select from the list what function key or touch strip you want to activate.
Next select ADD in the ACTIONS window from the list select EQ on faders and select which action you want, Toggle or select one of the 2 ranges.
If you select a range I assume that you would want to do the same thing for another key for the other range.
I would select toggle so with one key you can go back and forth between the ranges.
I hope this helps
Old 10-04-2014, 10:59 AM
Thanks!! Will try on Monday. :)
OS 10.7.5
PT 10.0
8 gig ram
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 10:56 PM
2.7.1 - Mix window faders & MC Mix faders ? priorytools Artist Series 2 05-14-2013 03:37 PM
Blue Faders vs. New faders sputnikestudios ICON & C|24 1 03-07-2013 06:55 AM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 07:44 PM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 08:06 PM
