Old 12-22-2016, 02:18 PM
TanukiJessica TanukiJessica is offline
Default Arturia V not working with PT10
I'm having issues with setting up Arturia V collection 5 with Pro Tools 10
I can't seem to get PT to recognise the files, it says that certain files are moved to the un-used folder on start up and i'm guessing i need to transfer these files into the used folder but everytime i do, it says it can't find them (also they don't look like the same file types).
I've also had issues with Addictive Drums 2 not being recognized, although Addictive Drums 1 is and works fine.
Can anyone give advice?
Thanks.
Old 12-22-2016, 02:35 PM
Southsidemusic's Avatar
Default Re: Arturia V not working with PT10
Hi and Welcome to the Community
Here are the specs for PT10 and up.
Required configuration
Works in Standalone, VST 2.4 (32-bit and 64-bit), VST 3 (32-bit and 64-bit), AAX (32 bits with PT 10.3.8, 64 bits with PT 11), Audio Unit (32-bit and 64-bit), NKS.VST 2.4VST 3 AAX AU NKS
You need Pro Tools 10.3.8 minimum for use of the aax32 bit. If you don't have 10.3.8 it won't run. Update from your Avid account to the latest PT10 and you should be good to go.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-24-2016, 02:54 PM
WernerF WernerF is offline
I'm still using Pro Tools 10 HD here and I have the Arturia 5 collection. I can load all of them but certain ones still crash Pro Tools. Mini V is one of them. The older Mini V still works. Also, the new free MiniFilter plugin crashes the system anytime that you attempt to instantiate it. It's too bad because they make some pretty cool sounding stuff. Let us know how it goes once you get them to show up, probably by getting the last upgrade for Pro Tools 10.
Old 12-24-2016, 07:34 PM
The Moog Mini emulation can be a cpu hog when it wants to be. More so than any of the other Arturia synths even the Moog Modular. For the record I have yet to see any developer's Mini emulation that doesn't suck up the cpu strength something fierce.
Jack
QAPLA!
DeckLink Studio 4K pci video out not working on PT10.3.8, but working on PT 11.3.2 abes Post - Surround - Video 3 04-18-2016 01:19 PM
Arturia Spark 2 - $100|Arturia Spark EDM & Vox Continental including eLicenser - $100 hatepop Buy & Sell 2 10-26-2014 06:46 AM
ARTURIA SPARK WORKING in PT 11 cstars AAX Plug-ins 0 08-02-2013 10:37 AM
ELS Vocoder not working in PT10/ML powerjoe macOS 0 03-05-2013 07:47 PM
PT10 working off of a NAS Frank Kruse Post - Surround - Video 19 01-27-2012 04:27 PM
