Digi003 (Console) + Automation [solved]
I am using a DIGO003 console with PT11. It has 8 channels with touch sensitive faders. However, when I switch through BANKS of faders (8 faders at a time), it is skipping banks. In fact it appears to be switching through 16 channels at a time, which is useless since there are only 8 fader channels on the console.
Is there a setting for this somewhere? thanks, Geoff |
Re: Digi003 (Console) + Automation
Just found a solution here (http://duc.avid.com/showthread.php?t=293084)
THANK YOU!
I didn't know what I did to make my Digi skip banks but your fix was instant. The forum is SO helpful. Thank you. With this problem fixed, I am back to trying to hook up my midi controller. What is the impact of your fix: e.g. selecting "none"? I hope to set up two controllers, one a cheap Casio piano and the AKAI MKII mini (pads, knobs, and keys). Will "none" be a problem? THANKS again. Jerry |
PT12 with Digi003 Console - Automation Problem | Zoduati | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-25-2017 12:20 PM |
PT12 with Digi003 Console - Automation Problem | Zoduati | macOS | 2 | 12-21-2016 04:11 PM |
PT12, Digi003 Console Automation | Zoduati | macOS | 0 | 07-12-2016 06:12 AM |
Digi003 Console, 10.3.6 and the new Avid 003 driver | TimR | Pro Tools 11 | 3 | 06-23-2013 08:23 AM |
Windows 7 64bit / Digi003 Console | krazylain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-21-2010 04:03 PM |
