Old 08-03-2019, 01:31 PM
Mr Base Mr Base is offline
Default DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL
Dadman and PT on same computer when PT is in focus, monitor tab of PT | CONTROL is blank. Until DADMAN is in focus it remains blank.
Is there any way to run DADMAN on a 2nd computer so its always in focus or another configuration for 1 computer so u do not have to focus DADMAN every time you want to use the Monitor Controls ? Will PT Control worth with 2 Eucon Sources 1 being DADman on 1 Mac and PT on the other Mac ?
Can this be done with 1 or 2 MACs ?
Thanks
Old 08-03-2019, 04:48 PM
Default Re: DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL
Thanks
You can lock monitor control to DADman in the EuControl app. It’s in one of the tabs (I forget which).
https://lukehoward.com/
Old 08-03-2019, 11:06 PM
BScout BScout is offline
Assign Tab.
That's how it should be done.
Need Pro Tools on two separate computers to be able to access two Apogee Symphonies MSCStudent Pro Tools HDX & HD Native Systems (Mac) 9 07-28-2018 03:24 PM
procontrol to control both HD3 version8 and 003 version10 on separate computers iain.sbprod ProControl, Control|24, Command|8 1 10-08-2015 12:28 AM
LOCKING LOGIC TO PROTOOLS- BOTH ON SEPARATE COMPUTERS gw sound Pro Tools TDM Systems (Mac) 10 06-29-2007 09:39 AM
Reason and PT LE on separate computers... AdamF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-30-2003 12:56 AM
Using Separate Computers for Soft Instruments/Synths Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-01-2002 08:29 AM
