Old 12-29-2017, 05:55 AM
akhafaji akhafaji is offline
Default Connecting Genos with Omni?
Hi
I bought Yamaha Genos and I found that the outs are unbalanced.
I have HD omni and all inputs are TRS/Balanced.
I have bought a TRS to TRS cable and connect the devices.
my question is related to connecting unbalanced device to balanced device.
Q) In the OMNI HW, Is it better to change the lines that used with the Genos to -10dBV or keep it to +4dBu?
I'm asking because the sound is low with +4dBu and higher with 10dBV.
Regards,
AK
Old 12-29-2017, 08:41 AM
john1192 john1192 is offline
Default Re: Connecting Genos with Omni?
Originally Posted by akhafaji View Post
Hi
Regards,
AK
have you tried the SPDIF output of your Genos into the Omni ??
and since this is a Synth yes, you would probably need to set the OMNI to -1o on that inout for this .. or use a Stereo DI into Micpreamps ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-29-2017, 09:05 AM
No, I did not tried SPIDF, is it going to sound better?
Ok, I will use it with -10DBV.
Regards,
Ali
Old 12-29-2017, 09:59 AM
Regards,
Ali
i have no idea if it will sound better .. but it is a simple one cable connection ..
the analog might give you something you like or maybe not .. will be your preference as i do not own your same gear i would not venture to have an opinion ..
please let us know how it goes .. all good info gets passed along to the next poor soul looking for an answer !!!
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-30-2017, 11:00 AM
nst7 nst7 is offline
Going Spidf should sound a little better since you’d have one less step of digital to analog and analog to digital conversion.
Old 01-01-2018, 09:15 PM
Sugarnutz Sugarnutz is offline
Just make sure you have a “Digital” SPDIF cable and are not using an analog RCA cable.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Connecting External RVRB hardware unit to HD OMNI mars100 Pro Tools HDX & HD Native Systems (Mac) 4 07-13-2016 01:05 PM
Connecting two computers to an HD Omni? sk3lut0r Pro Tools HDX & HD Native Systems (Mac) 1 09-03-2015 01:18 PM
Any harm in connecting an Omni to a live HDX card? TAMBOR Pro Tools HDX & HD Native Systems (Win) 4 01-19-2014 03:41 PM
Is there a recommended order for connecting a Omni and HD 16x16 phatbeatstudio Pro Tools TDM Systems (Mac) 1 07-08-2012 06:38 PM
Need help with connecting Lexicon PCM 80 to HD Omni JoeM Pro Tools HDX & HD Native Systems (Mac) 4 04-15-2012 08:40 PM
