Old 12-15-2002, 08:33 AM
zaneschroeder zaneschroeder is offline
Default Records one channel and then....
I am trying to record some virtual synths into ProTools. I have XP, 5.3, an additional SB PCI512 cound card, all works well. In ProTools, when I have my synth running, I can record one channel fine. It plays back, it records fine, etc. When I try to add another synth channel, it doesn't play or record. I know the synth portion is working, I get the signal into my mixer. But try as I might, that signal, doesn't get into the AMIII card, or ProTools. ?????
HELP!
Thanks,
zaneschroeder
Old 12-15-2002, 11:02 PM
Roy Howell Roy Howell is offline
Default Re: Records one channel and then....
zane,
To record multiple Midi tracks in PT, you need to create a Stereo Aux track, assign it's inputs to the same inputs you have your synth plugged into in the DigiBox. Then on each Midi track you create, you need to assign it as Digidesign Midi ch 1, ch 2, ch 3...etc.
Also, make sure your synth is set on it's Multichannel mode(it won't be called that usually... mine is the Sequencer mode. Mine won't play more than one channel at once in it's Program mode, for instance.)
Hope that gets you going. Post back if you need help though...
~Roy
rh music
Old 12-16-2002, 04:24 AM
Roy, thanks for the reply. I didn't explain this well. I'm not recording midi. I'm trying to record audio. On the first channel, I can play my midi keyboard, and play the synth, see a signal in the mixer, press record in ProTools, I can hear it through the monitors, and I can record it. I add a track, and try to do the same thing, and the signal is in the mixer, but ProTools won't "monitor" it, or record it. I'm sure it's a simple thing, but I can't figure it out.
THANKS GUYS!
Old 12-16-2002, 04:26 AM
forgot to add one thing.........it's a soft synth...Native Instruments......FM7
iMac Photobooth Records Left Channel of 11R only pete_g Eleven Rack 20 04-27-2013 08:19 PM
Strange CoreAudio issue - right channel information getting into left channel -JK- Pro Tools 9 5 01-10-2011 09:42 AM
Multi-channel plugin default 'channel view'? Floydio Tips & Tricks 1 11-26-2010 11:47 AM
Selecting a Channel on Icon does not select channel in ProTools teacherman ICON & C|24 2 06-07-2010 12:59 PM
Anyone doing records at 96k? OD Pro Tools TDM Systems (Mac) 9 08-30-2003 12:06 PM
