Old 05-09-2019, 07:09 PM
killah_trakz's Avatar
killah_trakz killah_trakz is offline
Default Uninterrupted Playback
I don’t see where this feature is. I updated to the 5.2019 update and my protools STILL skips and stops playback when adding plugins or adding tracks and all that other **** they were boasting about.
WENT FROM HD TO M-POWERED
Old 05-09-2019, 07:36 PM
Default Re: Uninterrupted Playback
Works great here. I can add tracks, plugins, sends and change IO. The only way I can make it glitch is by making tracks active or inactive. Tough to offer any insight with zero details on your setup
Old 05-09-2019, 09:09 PM
I had to delete the 2018 and re-install 2019.5. So far pretty good but STILL doesn’t handle core processing smh.
Advice needed on UPS Unit (Uninterrupted power supply) Seafoam_Green Tips & Tricks 9 09-09-2014 05:35 AM
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
What should be hooked up to UPS (Uninterrupted Power Supply) word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-27-2010 04:15 PM
Uninterrupted Power Supplies word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-14-2010 03:02 PM
Uninterrupted playback when assigning inserts?? Skwaidu Tips & Tricks 79 09-03-2002 05:03 PM
