Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-30-2011, 01:34 PM
caine27 caine27 is offline
Default Pro Tools and Garage Band
Hey I was wondering if anyone was having troubles with Garageband and PT being the potential problem.
I have PT9 and it works ok but when I try to load up Garageband its unable to open and gets stuck on initializing. I then proceed to contact apple support and they came up with the conclusion that it seems like its something PT was doing because when I ran safe mode we got it to open up but then their seemed to be asking something about pace drivers. So in short I guess my question is, is their someway PT can mess up GB and if there is, is there a way to fix it without having to reinstall the OS?
Im running 10.7.1
2.2 Ghz unter core i7
4 GB 1333 Mhz DDR3
PT9 with M-Audio Fast Track Ultra
Please and thank you
Old 10-10-2011, 06:09 PM
Rebel Rebel is offline
Default Re: Pro Tools and Garage Band
I'm also experiencing this and it's very frustacting.
It's not just Garage Band. Try to open the MIDI window under "Audio MIDI Setup" and you will also realize that MIDI window loads forever.
However, you're likely to be able to open the same applications once Pro Tools is running.
Mac Book Pro
Mac OS X 10.7.1 (Lion)
(drivers already updated as suggested by DigiTech)
Pro Tools and Garage Band tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2011 09:30 AM
Garage Band with Pro Tools LE 7? sjmagri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2006 12:55 AM
How to hear Garage band in/through Pro Tools? polaredit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-27-2006 11:29 AM
Using Garage Band samples possible with Pro Tools? ragbor Pro Tools TDM Systems (Mac) 0 06-24-2004 01:49 PM
Using Garage Band with Pro Tools? ragbor MIDI 0 06-24-2004 01:47 PM
