Old 06-27-2005, 07:45 AM
Matt Chan Matt Chan is offline
Default question about change notes
i have a quick question about change notes. my understanding is that, when performed in order, processing a change note will result in the properly reconformed reel. does this mean that the timecode/feet-frames numbers listed down the first column represent a running update as the changes are performed?
thanks in advance,
matt
Old 06-27-2005, 11:27 AM
JKD99 JKD99 is offline
Default Re: question about change notes
yep
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 06-27-2005, 11:48 AM
Noiz2 Noiz2 is offline
Yes, and the reason that you must do the changes in order.
Before slicing and dicing you may want to check the note if an assistant hasn't already. Go thorough adding all the additions and subtracting all the deletions from the old LFOA and see if you end up with the new LFOA. You might be surprised at how many "bad" change notes get sent out.
thanks in advance,
matt
www.scottkouesound.com
SK
Old 06-27-2005, 11:50 AM
brilliant! it sure beats trying to decipher an EDL and having to do everything backwards.
thanks to both of you.
Old 06-28-2005, 03:44 AM
Wait till you´ve done it ;-)
Frank.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
HTML code is On
Can i change tempo without moving MIDI notes? denormaliser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-24-2006 09:38 AM
How do you change midi notes' timing? Finnish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-30-2006 04:06 AM
PT7 MIDI-notes, how to change color (can't see)? Finnish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-08-2006 01:17 PM
Music Question: how do you change it from 4/4 to sixteenth notes?? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-08-2002 01:22 AM
AVID Change Notes JKD99 Pro Tools TDM Systems (Mac) 6 07-08-2000 01:01 AM
