Old 10-30-2007, 08:23 PM
Ormond Ormond is offline
Default What!!!!??? Absurd Cannot Save Neo Assertion!
iMac 24inch. 4MB - Aluminum.
Second drive is a GTech from Apple - top of line.
Cannot save my work.
Error says,
Could not complete your request because Neo Assertion in "/Volumes/Development/vb_cliff/AlturaPorts/SDKs/NEO61/Libraries/Macintosh/Environments/Alone/../../../Source/CNeolOBlock.cpp", line 164.
Help....I cannot get my work done! Due tomorrow afternoon!
Old 10-30-2007, 08:48 PM
sunburst79 sunburst79 is offline
Default Re: What!!!!??? Absurd Cannot Save Neo Assertion!
Delete the Digidesign Database folders on the root of each hard drive (system and external) Empty the trash, reboot and relaunch PT.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 10-30-2007, 10:31 PM
That worked, Cleveland.
What do I need to do to keep this from happening in the future? I was just reading that 7.3.1 addressed this issue, and I have it installed....so what do I need to do? continue deleting databases? They are easy enough to find with
"Spotlight" on the Mac. I had about 10 of them.
Go Browns. If Baltimore beats Pittsburg this week it is a 3 way tie for first.
Old 10-31-2007, 09:00 AM
Its just a ongoing PT "Quirk" Er Irk!.
You will see the phrase "Trash your Prefs and Databases" and this is what it refers to. The Digidesign Databases as I understand it hold info on wether that hard dive is a valid PT recording volume or transfer volume and no harm is done by deleting them as they will be "Rebuilt" the next time PT launchs if they are missing. They probably contain some indexing info the sessions also.
At any rate a couple of good PT tips is to repair "Disk Permissions" after any new software installs, and to know where to find the various "Prefs" and "Databases" that need to be trashed.
I haven't had to trash my actual prefs in foreever but a little searching will turn up the locations of those files also and you should have a rough idea of were they are located in case you run into a situation where you ned to trash them also. The various "Prefs" contain info like your I/O settings and the like. If you actually have to thrash your prefs at some point you may have to reset some of your PT "Settings" so to speak. The Prefs are PT's equivalent of a UNIX/Linux "plist" file
A neo access error uasually means someting is corrurpt with the database and not the actual files thankfully.
I'm not sure that explanation is 100% accurate but should give you a feel for how PT handles objects on the hard drive.
I would like to see somebody win around here during my lifetime
Scott
Core 2 Specs Page
Can't Save + Assertion Line 320 - 10.3.5 Xollop Pro Tools 10 3 05-20-2013 08:04 AM
Could Not Save because Assertion in "CNeolnode.cpp jkennedy333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-04-2006 12:16 PM
Can't Save...Assertion error or something barky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-01-2006 12:43 PM
what does "could not save song because Assertion cc1 Pro Tools TDM Systems (Mac) 1 05-04-2006 12:22 AM
Cannot Save!! Assertion "CneolBlock.cpp," line 164 Sammy9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-27-2006 10:07 AM
