Old 01-31-2006, 05:19 PM
spkguitar's Avatar
Default Re: Project Mix I/O - HUI Controller
As to not high-jack the thread from the original poster, I will ask a similar question..
From what I have read it looks as though you need to run the Project Mix I/o under HUI in Pro Tools M-Powered 7. Is this correct? Rather, If i do not have HUI selected under "Peripherals" the unit wont communicate. Correct?
That's what is says on Page 17 of the Project Mix Manual
Setup: With the ProjectMix I/O in Pro Tools mode, launch Pro Tools and select Hardware Setup > Peripherals > MIDI Controllers. Under Type,
select HUI. Under Receive From, select ProjectMix I/O Control. Under Send To, select ProjectMix I/O Control.
Old 01-31-2006, 05:26 PM
dogselur dogselur is offline
I connect it through firewire. I believe that is the only way to connect it. the MIDI is just the language it uses to communicate, not the cable type.
Old 01-31-2006, 11:59 PM
Re_Org Re_Org is offline
Hi Dogselur,
in fact, I was wondering if it could work with a digi 002. And the Digi 002 is Firewire, that's why I'm not sure they can work together.
So PTools LE makes no difficulties to integrate midi via firewire in "Peripherals" ? Great...
I want to be able to use it as 8 more faders for my 002 (16 faders ) when I don't use it with my MPowered system...
Thanx,
Dom
Les Tambours du Bronx
RE_ORG
Old 02-01-2006, 07:24 AM
wjs23 wjs23 is offline
<3 thanks.
Old 02-01-2006, 07:36 PM
well, I am not sure either that they can work together, BUT, I know that you can select more than one interface in the peripherals dialog. So it might be possible. If you are just using the Projectmix for more faders, Tascam might have a better product for you. They have a 24 fader board. To use the Projectmix's inputs you have to run M-powered 7, which may not work with digi 02. just some thoughts....
  #16
Old 02-15-2006, 12:45 AM
Well, I have a MPowered system for the tour dates, so I can run it when I need to have more preamps...I can run it with MPowered and use the ADAT out and go straight into the ADAT In of the 002 (on a PowerMac PTools7)... I can take it on tour with my iBook... And when I'm at home I could perhaps use the ProjectMix as an extension faders pack for my Digi 002. But I'm not sure at all that it works... And I have some problems with checking that !!
I'm afraid that projectmix's firewire could be in conflict with Digi 002... And I don't know if using MIDI cables only, I can set up the ProjectMix for a kinda standalone mode... Or if I have to run MPowered just to have the ability of using MIDI for PTools 7 Peripherals...
Tons of questions here...
best regards,
Dom.
Dom
RE_ORG
  #17
Old 02-28-2006, 11:25 PM
TBF Entertainment TBF Entertainment is offline
The Project Mix works great with PTMP7. This is my first mixer that works with any type of recording software. So I think it worrks great. The Master fader controls nothing. It is not mapped in the software. I don't know if it can be or not. Other than that, i think it works great!
TBF
  #18
Old 03-02-2006, 10:57 AM
zkaudio zkaudio is offline
I love mine, only thing I'm a little upset about are the minor bugs, i.e. device disappearing in windows, just little glitches here and there. All these glitches could be EASILY fixed by a firmware and driver update... yet m-audio's newest driver set is from 5 months ago... call me naive, but I know lots of hw companies that can bang out great driver sets in A DAY.
Anyone using M-Audio Project Mix I/O as a controller? forgotteng 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-12-2008 07:10 AM
project mix i/o as hd midi controller carl_laruso Pro Tools TDM Systems (Mac) 1 02-07-2008 12:05 PM
making a project sound like a project skwad Tips & Tricks 2 01-25-2007 05:54 AM
how to connect midi controller to project mix? GStyle Pro Tools M-Powered (Win) 1 03-21-2006 10:29 AM
Case/Project box for MBox Project? RMcFarland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 02-23-2004 05:31 PM
