Pitch II audiosuite processing question
I am going through and using audiosuite EQ and pitch shift to modify some elements in my sound design.
My EQ 3 plugin, I have set up to go clip-by-clip and I get the 2 second handles, and it doesn't render my fades. Exactly what I wanted it to do. However, on the pitch shift plugin, the "clip-by-clip" option is grayed out and I can not get it to process with handles and it is rendering the existing fades into the clips as well. Is there a reason the clip-by-clip option is grayed out? Or is there a different way to set it up to process while processing the handles and preserving the fades/edits? EDIT: System specs would probably help... OS 10.12.2 PT HD 12.7.1 4.01 GHz Intel i7 64GB RAM Last edited by Inglesworth; 01-16-2018 at 12:18 PM. |
Re: Pitch II audiosuite processing question
That sounds familiar as an old bug (thought it was fixed).
Sent from my iPhone using Tapatalk |
question about audiosuite dither setting under processing preferences | collinsylex | Pro Tools 9 | 4 | 03-11-2011 11:36 AM |
Audiosuite processing | Reckah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-25-2009 02:20 PM |
AudioSuite NOT processing | Abomb97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-09-2004 01:10 PM |
Audiosuite not processing | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-06-2002 10:26 AM |
AUDIOSUITE NOT PROCESSING | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-19-2001 05:52 AM |
