Re: Artist Mix Cubase integration
The latest version of Cubase have the adapter included so this should be OK. The freezing could be many things unfortunately from Cubase to EuControl or even the power supply. Is the unit still visible in EuControl when it freezes?
Yes, the unit is visible.
It might the eucon software problem because after restarting the application twice (while the project is still running) it regains connection. With some projects, however, sometimes it just doesn't work at all. This is quite rare, usually with BIG projects, but I do get those sometimes, and this is the time I need the artist mix the most. Just trying to throw as much information as I can to try to narrow down on the problem. Between this and the initial irregularity that I posted, something is definitely not completely right. |
Can you try disabling EUCOn in Cubase and reenabling...see if that fixes it too
Cubase 8 or 8.5 - Artist Mix not working / El Capitan 10.11.2 | webber | Artist Series | 7 | 10-17-2016 02:01 AM |
Artist Mix and Hidden Tracks in Cubase | J-S-Q | Artist Series | 2 | 07-16-2014 03:51 AM |
Artist series and cubase 7.5 | trock | Artist Series | 12 | 03-11-2014 01:30 PM |
Cubase 6+Artist | robertg | Artist Series | 2 | 02-26-2012 01:12 PM |
Registering Artist Control v2 with Cubase | The Red Rooster | Artist Series | 0 | 08-01-2011 03:03 PM |
