xpand2 drums
Hey guys
my set up is an m audio m box 2 with protools 8 along with a macbook and an m audio evolution keyboard. The problem I have may be an easy one to solve. I have plugged in the gear and am ready to go but when I load up xpand2 and load up a drum kit the top half of my midi keyboard is mute and there is no kick or snare. Its almost as if everything needs to be shift up and the kicks and snare are at the bottom half. I have made sure that I have loaded up a kit with snares and kick so this is not the problem. Any help would be so greatful cheers |
Re: xpand2 drums
There was a way to do that in early Xpand. Maybe in Xpand2 as well...something like the transpose, hi/lo key. I'm sure if I looked in the manual again I would find it.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
Re: xpand2 drums
Have you tried shifting the octaves on your MIDI controller or are the snares and kicks not even existing on the keys at all?
iMac 2.4 GHz Intel Core 2 Duo, 4 GB RAM, OS X 10.6.2, Mbox 2 Mini, Pro Tools LE 8.0.3, Reason 4, M-Audio Studiophile BX5a monitors, Akai MPD18, M-Audio Keystation 49e, Furman SS-6B surge protector |
Re: xpand2 drums
The kicks and snare just aren't there.
They are loaded up on xpand but I can't assign them. It's like the bottom half of the keyboard is where the top half should be and the top half is just mute. It works fine for synth effects and everything else, just not drums, which I am unfortunately relying on :S |
Re: xpand2 drums
Hi Thisguy,
How many keys on your m-audio keyboard? You may have to transpose up a couple of octaves since on most (all?) keyboards the seemingly default layout has the kick and snare starting on the lowest C and then everything ascending from there.
21.5" (Late-2015) 11,2 iMac i5 2.8GHz, 16Gb, PT 12.8.2, Metric-Halo ULN2 2d Exp'd w/Sierra 10.12.6 |
Re: xpand2 drums
It's possible that you are choosing the drum kit selector/builder "parts" from the plugin dropdowns (the ones that are actually a part of the Xpand2 interface) as opposed to using the plugin "presets" in the standard preset menu. This is the one that says <factory default> when you open a new instance of Xpand.
You should try using the "presets", not the "parts" until you figure out how the parts work together for drums..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: xpand2 drums
Thanks for getting back to me
arneal, that sounds like the problem, how do I go about tranposing it up an octave? It's a 37 key m audio evolution? P.s I am using the presets |
Re: xpand2 drums
Ppppllleeeaaassseeee hhheeelllllpppppp :)
Re: xpand2 drums
What Patch? And have you set the MIDI Controller an octave up?
Aaron Mulqueen - 001 HD Native |
Re: xpand2 drums
Drum patch using any of the preset kits.
The snare and kicks aren't being played and the top half of the midi keyboard is muted. Someone has suggested it needs transposed up and if so how do I do this? Otherwise any other suggestions what's going wrong? Many thanks Duncan |
My electric drum kit won't work with Xpand2 Drums but works fine with Boom? | thrice506 | MIDI | 7 | 03-26-2014 04:58 AM |
Midi Drums and bass (Xpand2) lose sync-aye carumba | scrnplyr | macOS | 4 | 04-02-2012 11:32 AM |
"XPAND2.big" Xpand2 Can't Finde The Factory Content?? | toolgirl | macOS | 1 | 02-29-2012 08:04 PM |
"Xpand2.big" Xpand2 closes PT10 | RamenShaman | macOS | 3 | 01-03-2012 08:44 PM |
Xpand2 midi patterns used with Drums in Ballad Guitar session template | Brian Mac | Virtual Instruments | 2 | 06-21-2009 09:27 PM |
