What does "native" mean in terms of PT systems?
As it says on the tin. For some reason I have managed to get through 4 years of operating ProTools without ever working out what this means. it is causing me considerable discomfort.
What is a "native" system? Excuse my ignorance. Thenks. |
Re: What does "native" mean in terms of PT systems?
One that runs solely on the "guts" of the computer... as opposed to HD which used the power of extra process cards..
Thanks you.
Does this mean it has no DSP or anything on board? And as such, requires an extremely efficient computer to run at high sample resolutions? Cheers. |
That is for the most part true. Modern computers have advanced over the years that much of the digital audio processing can be done using the computer's processor "native.". In previous systems, additional DSP power was needed to support the higher sample rates and track counts. Today, use of DSP is more often associated with specially optimized plugins that take advantage of those DSP processors.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.4 running Protools 2024.3 Mac Studio M1Max - 64GB MacOS 14.3.1 running Protools 2024.3 |
And more I/O
Although there is an HD native card. The card itself enables the use of the HD gear by connecting them into the card, but the card doesn't do any processing. All the processing is still done by the CPU(S) And as far as I know, even with that card, you can not use the TDM plugins.
HD/TDM systems use the TDM process/accel cards to do the mixing. Your track count and I/O are dependent on how many cards you have in the system. You'll notice people have HD1, HD2, HD3, ect. systems. This refers to how many TDM cards they have. These systems only work with HD interfaces. Native systems use the host cpu to do the mixing. Under PT9 they can use any Core Audio or Asio interface. HD/Native uses the host CPU but allows the use of HD interfaces and has more simultaneous I/O than a Native system. However you do loose the ability to use TDM plugs and some of the other things TDM cards add over a native system. There are other processors out there you can add to either system, like the UAD cards, but they don't change whether the system is TDM or Native. They simply give the host CPU more power.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
If I am not mistaken, when Apples next gen mac pro comes out with either a 16 or 24 core and adding 10gb+ of ram and when PT goes 64bit, with HD native, you will have far more power than an HD3 (minus Heat and TDM) for less than half the price.
But that's just my guess. |
Truthfully, I'm pretty confident and with high hopes that when PT 64 comes out, we'll have new hd gear that will blow our socks off. It would be a real slap in the face of the pro users to come out with a new platform that doesn't have any professional gear that goes with it. |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
terms......"root folder"...etc | gitarzan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-13-2003 12:25 AM |
terms.... "root folder"... etc | gitarzan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-12-2003 11:23 AM |
"LINKING MULTIPE DIGI OO1 SYSTEMS FOR MORE TRAK COUNT" | G-MIX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-04-2002 06:51 AM |
