adat bridge word clock
I have just purchased a digimax pre from presonus. I have attempted to sync it to the word clock out of the adat bridge, but for some reason the digimax sees superclock. I have gone directly from my clock master(MTP AV) with super clock off and it syncs up. Any thoughts? Thanks
Re: adat bridge word clock
The word clock from the ADAT bridge will not drive very much cable. I had to keep cables shorter than 2 meters inorder to transmit wordclock successfully. I checked this fairly thoroughly with an Oscilliscope.
I would suggest a lucid or aardvark wordclock distribution amp if you need to drive any kind of cable length. |
That was it! Thanks for the post. I had to reduce the length of the cable in order for the digimax to sync-not a very strong output from the adat bridge indeed!
Clock Source: Word or Optical ADAT? | RobMacki | Pro Tools TDM Systems (Mac) | 7 | 04-15-2006 06:32 AM |
ADAT Bridge clock problems | TLarkin | Pro Tools TDM Systems (Mac) | 5 | 08-17-2004 12:51 PM |
Word Clock in ADAT bridge | centerstage | Tips & Tricks | 3 | 08-22-2003 12:18 PM |
192 i/o ADAT word clock | shadowbox | Pro Tools TDM Systems (Mac) | 3 | 09-29-2002 03:29 PM |
What is the word on the ADAT Bridge 24 bit upgrade??? | -MaxTraxStudios- | Pro Tools TDM Systems (Mac) | 8 | 03-10-2000 08:24 PM |
