New guy here and looking for some advice
I was watching a review video last night and the gentleman said two things I'd like to verify. I should mention that I'll be using this unit live. I don't do any recording at all.
1."The Eleven Rack can be used as a head connected directly to a speaker." 2. you can use either a midi controller or(and I don't recall what he called this) an analog switching pedal to control the unit. I'll need to procure a floor rig to switch between effects on the rack but I don't think I need to be able to change parameters and such on the fly. So my questions are, do I need a power amp to run this through a speaker cab or can I run it through the cab without? What are some options for a stompbox type pedalboards to control the unit? Is there something other than MIDI that'll do the trick. Thanks guys be gentle please. I'm both new(to this) and old(in age). |
Re: New guy here and looking for some advice
1- a POWERED speaker? Yes. The Eleven Rack has no internal power amplifier.
2-Any midi foot controller should work. Some options: Behringer FCB1010 Voodoo Labs Ground Control or Ground Control Pro Random Thoughts: You might be happier with the Headrush Pedalboard. It takes the Eleven technology and stuffs it full of steroids(and it's already a complete foot controller, in addition to all the amp/cabinet/pedal emulations). Next up the ladder is the Line 6 Helix. After that, I would go for a Kemper(which CAN be bought with stereo power amps built in) but that's the high-priced solution Most of these units work best when sent direct to the PA(which you could do and use some powered PA-style speakers for stage volume). I recommend you hit your nearest big music store and start playing these options(and check out youtube for lots of demo and tutorial videos)
Thanks Dave. Good info all. Appreciate you.
Without a midi floor controller, you are limited to a dual momentary switch OR an expression pedal to control parameters. Dual momentary switch can, as an example, do rig up/down, or can on/off blocks (distortion, modulation, delay, reverb, etc).
I just ordered a Midi Mongoose (but not received yet) which looks like a nice little midi foot controller for the price (I want something small). A guy is selling its Rocktron All Access for $400CAD in kijiji Montreal, which is a top notch solution. As a reference, I play my 11R thru an EV ZLX12P and ZXA1 sub (I play bass also), powered PA top and sub. |
advice on what to buy | allinthemind | Pro Tools TDM Systems (Mac) | 12 | 08-20-2007 01:20 PM |
Advice on my 192..... | Aaron Palmer | ICON & C|24 | 1 | 07-20-2007 10:05 PM |
A little advice | Doriengray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-18-2006 05:57 PM |
First PT Mix - Advice? | tommytime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-10-2003 10:20 PM |
NEED ADVICE! | patrickb | Pro Tools TDM Systems (Mac) | 0 | 06-05-2000 08:05 AM |
